In canon 3530, what s the error code of E000520-8001 give me details plz..
4 Suggested Answers
  • 122 Answers
SOURCE: sir, my canon ir 400
the code 803is for faulty exposure lamp or fault in composite power supply(the power supply to exposure lamp is not sufficiant to operate the lamp).to remove exposure lamp, remove copyboard glass,remove back cover ,slide scanner in the line of rear exahaust fan at the right side of scanner, remove rear exahaust fan, remove lamp holder(one screw).slide out lamp on the rear side replace new one and reverse the whole process.
Posted on Jan 27, 2011
muleskinner2
  • 270 Answers
SOURCE: I am using Canon IR
I had the same problem on a IR-2230 and I had to replace the Developer Assembly. Check the connection first - have you recently had this worked on?
Posted on Jun 22, 2011
canontech
  • 1219 Answers
SOURCE: Model:- Canon ER 3530 Error Code :- E00000-0001
this is error code for abnormal temperature in fixing assy. You can try to clear the error, but if cllear doesn't help you, call service for fixing film unit replacement.
Procedure:
While the copier is in ready to copy mode or showing error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel
Now choose: COPIER>FUNCTION>CLEAR>ERR, turn off and on
Hope that helps!
Posted on Aug 26, 2011
Canon ir 3530 problem is error code is e000350-0001
The codes are meant for trained techs and are no fixable at home.
Jun 02, 2016 | Canon Office Equipment & Supplies
It says turn the main power switch off and on again in addition it shows an error code E000000020 or E00000007
If you wish to get some details about printers an copiers error codes and repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 21, 2016 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
JAM ERROR 0207 ON CANON IR 3530
Open the printer and remove the paper jam.
Dec 04, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
3530 error code 110-0001
how to solve the problem code E000000-0001
Jun 29, 2013 | Canon IMAGERUNNER 3530 Copier
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me....
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
Jan 06, 2011 | Canon imageRUNNER 400S Copier
E000024 error in my canon 3530 what can i do for it please help me
There doesn't seem to be an E024 in the error table. Must be something in the drum /toner area though.
Ensure all drums and sensors are clean.
SALT Sensor sometimes causes strange error codes.
Oct 06, 2010 | Canon imageRUNNER C3200 Copier
222 people viewed this question
jasbo
jasbo
