Question about Linksys Wireless-G WRT54GS Router (e125894)
Dell Inspiron 1150 laptop running Windows XP will not connect to wireless internet. Wireless Network Connection 2 shows Excellent and status indicates it is connected. This laptop use to connect to internet wirelessly. While bringing it to my house to fix, it did connect in Kansas City airport wirelessly.
  • 192 Answers
You wirless network might be protected by a WEP password which should be on the botom of the router
Posted on Jan 04, 2009
Dell inspiron 1525 not connecting to internet
I am one of the Dell Certified System Expert.
For internet connection, there are two ways to connect to the internet. One is through wired connection (connecting LAN cable) and connecting to wireless connection (through wireless router or through wireless Modem WLAN).
For wireless check the switch located on the left side of the portable after switching check the status light located at the front left of the computer.
check the driver if it is properly installed meaning no bang(!) or question mark(?) for both ethernet (LAN port) and Wireless Device.
To check the driver go to control panel then device manager. Check the network and you should be seeing the ethernet and wireless device. If not installed use the driver cd that came with the computer.
How to check the internet connection.
For Wired connection:
First check the cable, check the LAN port in the computer there should be blinking lights, if none try to reseat the cable. Check the ipaddress of the computer and the default gateway.
This is the instruction to get the IP address and default gateway.
For windows xp
1. Click start, then choose run then on the box type CMD then click ok.
2. on the black screen type ipconfig. get the ip address and default gateway.
3. normally it will give you 192.168.XXX.XXX
4. try to type ping 192.168.XXX.XXX (this should be the gateway)
5. If you receive replies, then you are connected to the router/modem
6. then try to ping www.yahoo.com
7. if still reply then you are connected to the internet already, might be your issue is browser or security on the computer.
For vista and Windows 7
click windows then in the start search type cmd, you should be seeing cmd on the top, right click then choose run as administrator. then follow steps 2-7 above.
For wireless connection
Check the switch, and the status light, if all are checked checked the ip address and default gateway as well, the instruction is the same above.
For more information about setting up your system please refer to the link.
http://support.dell.com/support/edocs/systems/ins1525/en/SG/Y465HA01MR.pdf
Hope this will help you a lot.
Thank you for choosing fixya
Mar 01, 2011 | Dell Inspiron 1525 Notebook
Wireless network problem with Dell Inspiron 600m.
Your wireless router is acting as the mechanism to hand out IP addresses using DHCP.
Sometimes glitches occur and I would recommend unplugging your wireless router from its power surce, letting it sit for a minute or two and replug it back in.
It will come back to life , reset itself and start handing out IP addresses to all computers and peripherals that normally connect to the router.
Nov 27, 2009 | Dell Inspiron 600M Notebook
When I try to run the Dell Wireless Configuration Utility from the control panel I get the following error message:"The wireless network adapter could not be accessed. This application may have diminished...
Well Sir in this case i will advice you to disable the Dell Wireless Configuration Utility and instead use windows utility for a successful connection.
For disabling dell configuration utility follow these steps:-
1)Open dell Wlan utility , it will have five tabs at the top labeled wireless networks , link status , site monitor , diagnostics and information.
2)Click on wireless networks tab and uncheck the first option which says , "Let this tool manage your wireless network" then click ok or apply at the bottom right-hand side corner of the screen.
To Enable Windows Utility for Windows XP follow these steps:-
1)Open the Control Panel from the Start Menu.
2)From Control Panel click on network and internet connections and then open network connections from there.
3)Right-click Wireless Network Connection and choose Properties.
4)
Click on the Wireless Networks tab and if unchecked , then check the box for Use Windows to configure my wireless network settings. Then click OK.
5)Right-click on Wireless Network Connection, Select View Available Wireless Networks.
6)
This will lists all the available wireless networks in range. Select your network from the list and click Connect.
7)If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key(which is the password for the wireless network) and then click connect.
8)Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wireless.
This Link will guide you through the steps:-
http://kb.netgear.com/app/answers/detail/a_id/111/kw/wireless%20zero%20configuration/r_id/100109
Nov 24, 2009 | Computers & Internet
I have a Dell Inspiron 6000 w/ window xp. I show my wireless connection on the signal is excellent but when i click internet explorer its says its connect to internet - i dont have working offline clicked...
Try connecting to another wireless connection... if it connects to another connection and you get to the internet, then it is something with your wireless router or modem. Your PC can "see" a wireless connection, so it is NOT PC hardware.
It sounds like you can connect to the router, but cannot go through the router to get to the internet. Probably a simple issue with your modem or router. Try power cycling the modem, and power cycling the router. Then restart your PC and try connecting again.
If all that fails, try installing Mozilla Firefox and see if that will get out to the internet. It may be a problem with Internet Explorer.
Sep 09, 2009 | Dell Inspiron 6000 Notebook
Wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Wireless router
I THINK YOU HAVE TO CHECK FOR A FIREWALL PROBLEM
THAT STOPS SOFTWARE FOR WIRELESS
Dec 06, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 5100 Internet Access
Do you have your computer connected to your wifi network and your ethernet cable at the same time? Try having it connected to only one and see if that changes anything (ie, keep the wireless on and unplug the cable, or keep the cable plugged in and disable the wireless - if your laptop does not have a button/switch to turn off the wireless, you can do so by going to your network connections area from the control panel, right clicking on the wireless internet icon, and selecting disable.)
Nov 08, 2007 | Toshiba Satellite A75-S226 Notebook
Unable to detect my router
This is because your router is setting your pc at a different IP address than your original modem. Make sure router is set to enable DHCP which gives out an automatic ip address and check your wireless card and network cards are set to obtain ip address automatically. It may take a few re-starts to get on the internet as your systems will need to clear their previous DNS settings. Also i assume you have set up the home network wizard (XP) as you are now using a router and not a direct modem. Also try Start>Run, then type ipconfig /flushdns then press enter.
Dec 27, 2006 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
214 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
