Question about Sub-Zero 632 / S
Regrigerator handle came off need to know the type of screw driver to secure the handle
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
I assume it is a factory stainless steel handle. There are set screws on the floor side of the standoffs. If you look at the bottom of the stand of you will see a small whole about 3/16 in diameter, inside this is a set screw. I cannot remember the exact size but it is pretty small allen wrench. Be careful when you are tightening not to scratch the stainless finish.
Posted on Jan 08, 2009
I need to replce the drivers side mirror. Just seeking instructions on how to.
Remove front door handle bezel screw cover Remove inside handle bezel screw Remove inside handle bezel Lift upward on the rear of the front door inside handle bezel Disconnect electrical connector Remove handle screw cover
Remove handle screw Remove door trim panel upper screw Remove door trim panel lower screw Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel
Disconnect mirror electrical connector Remove 3 exterior mirror nuts and exterior mirror
Mar 07, 2011 | 2009 Ford Fusion
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
Handle on bottom freezer door is loose. Screw on bottom of handle appears to be neither a philips or flathead screw. just seems like a teeny tiny rivet.. Inside the handle is a floating "ball"...
Hello, You need to look at the screw at the bottom of the handle. I know this is difficult to do; however, you have to establish what type of inset screw you have to faster. Most probably, it is a four or five star screw. You have to have a certain head screwdriver in order to turn the screw in order to secure the handle. When you identify the head of the screw -- as in four or five head screw -- place the screw driver into the screw and turn until it is firm.
If this does not work, refer to the manufacturer's manual to find a solution.
Hope this works for you. Dana
Dec 31, 2010 | Maytag MFI2067AES Stainless Steel Bottom...
Sub-Zero 601R door handle is loose
My Sub is a 650S. Not sure your handle assy. is the same or not. But each of the 2 attachment points have a small 3/32" set screw on the bottom of each short piece between the vertical handle and the door. These set screws grab onto posts that are screwed into the door. There can be 3 points where the handle can work loose.
1. The set screw(s) have backed out and not holding tightly onto the door studs. 2. The studs in the door are loose and need to be tightened with a screw driver. 3. After loosening the handle via the set screws, when you look back into the cavity vacated by the studs from the door, (pivot handle clockwise past edge of door) you will see a Philips-head screw that secures the spacer to the handle. If the spacer is loose, tighten it with screw driver. Then mount back into door stud and tighten set screw. Problem Solved. Have a beer!!!
Nov 26, 2010 | Sub-Zero 601R
NEED TO REMOVE DRIVERS DOOR PANEL ON A 2006 NISSAN 350Z
I did this myself before:
Removing the Door Panel
The first thing to do is remove the tab in your door handle that covers the screw (using the flat head screw driver), which secures the handle and window/lock switches to the door panel. Using the Phillips head screw driver, remove the screw. Now, remove the door handle and locate the tabs securing the wire harness for the door locks & power windows. Using the flat head, push down on the tabs and pull the male end out of the wire harness with your other hand. You can now locate 2 of the 3 bolts/screws that secure the door panel to the door.Using the 10mm socket, 3′ extension, and the 1/4′ drive socket wrench – remove the bolts/screws. Located behind the interior door handle is a plastic covering with a hole cut in it, that goes around the rubber piece that is there to stop the handle.Use the flat head screw driver to remove that plastic piece. Behind that piece, you will find the 3rd and final bolt/screw that secures the door panel. Using the 10mm socket, 3′ extension, and 1/4′ drive socket wrench, remove the bolt/screw. At this point you can pull the door panel off by hand.There are only tabs holding it on now, and they all will pop off. Now on the inside of the panel, you will need to locate the backside of the interior door handle. Remove the cables that operate the door lock, and opening mechanism. No tools are required for this step. Now you have the metal door panel, which is secured by 11-12 bolts/screws around the boarder of the panel.Locate the wire harness for the window motor in the upper right corner of the metal door panel. Using the flat head screw driver, disconnect the wire harness.After removing the panel, you will need to push the rubber grommet through the panel – the wire is attached to it. There will also be two white tabs on the backside of the panel that secure the female end of the window motor wire harness to the panel. Using your fingers (or pliers) pinch them, to remove the harness.
At this point, you can remove the 11 – 12 bolts/screws that are holding the panel to the door.The panel will not fully remove, but will come off a little bit. Now for the gold colored bolts/screws and nuts.Three of the bolts/screws are what secure the window motor to the panel.The other two bolts/screws, and the 2 nuts hold the brackets that hold the glass in place.there is one of these bolts/screws, and one of these nuts on each bracket (on each side). Using the 10mm socket, remove all of the bolts/screws.The Nuts are a 12mm socket; remove them as well. The panel should now come off, and the motor & guts of the door, will be revealed.
Apr 14, 2010 | 2005 Nissan 350Z
Need to remove driver side door panel?
  1. Disconnect the negative battery cable.
  2. If equipped with an accessory switch panel, carefully pry the switch panel up and away from the door panel. Tag and disconnect the switches from the panel.
  3. On 1981-86 models, remove armrest attaching screws.
  4. On 1987-96 models, remove the retainer screws secure the pocket in the molded armrest on the door panel.
  5. If equipped with crank type windows, remove window crank handle with the appropriate clip removal tool.
  6. If equipped with manual remote mirrors, remove the control knob bezel.
  7. Remove inside door handle cover attaching screw and trim plate.
  8. If equipped with door mounted speakers, remove the speaker, and disconnect the speaker wires. For speaker removal and installation steps, refer to .
  9. Remove all external screws securing the door panel. Insert an appropriate prytool between the door panel and door frame to remove the hidden clips securing the panel.
  10. Holding door panel vertical lift straight up to release the upper clip.
  11. Inspect all retaining clips and replace any broken or missing pieces.
To install:
  1. Position the door to the door and carefully press on the retainer clips to engage. If a clip will not engage, inspect the mounting hole behind the panel to make sure the clip is properly aligned. Install any panel-to-door retainer screws.
  2. If equipped with crank windows, attach the washer and crank to the window regulator stud.
  3. On 1981-86 models, attach the armrest to the door using the retainer screws.
  4. On 1987-96 models, insert the armrest pocket and secure in place with retainer screws.
  5. If equipped with door panel mounted speakers, attach the speaker wires to the speaker and secure the assembly to the door panel.
  6. If equipped with remote cable mirrors, attach the control knob to the door panel with the retainer bezel.
  7. If equipped with an ashtray, insert the holder assembly, and secure in place with retainer screws. Install the ashtray to the holder assembly.
  8. Position the door handle trim panel around the door handle assembly, and secure in place with the retainer screw.
  9. If equipped with accessory switch panel, attach the harnesses to the switches, and press the accessory plate into the door panel.
  10. Connect the negative battery cable.
  11. Check and make sure all panel components function correctly.
Apr 03, 2010 | 2002 Ford Explorer Sport Trac
Installing driver side interior door handle
pull the inner panel off by first un screwing the two screws located on the handle portion of the panel(they may have plastic hadeaway covers over the heads) then remove the window rolldown handle(if so equipped,manual window)then pull the plastic trangle from the inner of the mirror(this little tri angle keeps the trim down and secure on the door. then pull the palnel directly out there are small clasp pins in behind the panel try not to break these(but they do sell replacements at your local auto store) you will have to get ALL of these free then wiggle the panel up releasing it from the inner shell of the door and and window. you should now have a clean view of the handle. you will now need to droll out the rivit holding the handle to the inner steel of the door. pull the handle forward and it should be released from the inner steel now there clips holding the "rods" to the handles back side, they should have a little piece clipped to the rodto un clip these you need only push them off with your thumb. then replace handle with the new one, and uce a large steel screw to secure the handle when replacing back on door.
Nov 21, 2009 | 1998 GMC Sierra
How do i remove the drivers side door panel on a jag s type
This is the same front or rear door. 1. remove rubber insert at the bottom of the arm rest/door handle 2. remove the 2. philip head screws. 3. run hand along bottom edge of door panel to ensure no other securing screws. 4. starting at the top rear edge of the door panel side a large flat screw drive/door panel tool(what ever you have) 5. lift sharply and you will here poping noises fromt the push clips lifting out of the socket. 6. as you work down the rear edge of the door panel you will see the trim around the interior door handle lift away. remove it. 7. the interior door handle will remain on the door. 8. remove the rest of the door panel.
Oct 10, 2009 | 2000 Jaguar S-Type
Removal of drivers door panal. f 150 supercrew lariet 2001
Don't know what to do with the adhesive except to carefully remove with a long screwdriver, putty knife, etc. However, before you do that you should remove the screws in the door handle crevice. The two lower screws seem to come loose on their own so I replaced with one size larger stainless. The upper screws by the door handle are critical to remove the panel AND to secure it...
Feb 01, 2009 | 2001 Ford F150 Styleside SuperCrew
Cannot remove window handle
on the front face of handle looks like a groove around perimeter of handle ok? using a thin screw driver or suitable tool ? this groove is a panel that clips into handle to cover a securing screw for handle prise off gently from the narrow end nearest the wheel of handle ?
Jan 03, 2009 | 2005 Hyundai Accent
Sub-Zero 632 / S Logo
143 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
