I currently have a JVC XL-E3 CD Player. It powers up OK & plays CDs but the sound is very hissy with virtually no sound! Could the laser need cleaning or is there something further wrong?
This CD Player is a JVC Hifi seperate. All other components all work OK (Tuner,Cassette Decks & Phono). If you could help that would be much appreciated.Thank you in anticipation.
  • Rob getz Nov 11, 2012
    If it is sepperate from the rest of the system, My advice would be just to get a different one, To me it sounds like a problem with the lazer eye, In some of them what happens from heat the unit gives off while playing, The term us techs use is the lens gets milky,Then it will sound like (****) to put it mindly. It is verry costly to have it replaced, I have bought good used disc players for friends of mine for $7 to $30 at the most, At thrift stores or privately,One thing when buying one if it is dusty  inside when you open up the drawer, Stay away from it, Hope this helps you out.
simplemitch
  • 752 Answers
SOURCE: PIONEER DC-Z92 CASSETTE DECK AMPLIFIER
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
Posted on Oct 13, 2007
SOURCE: cd player not playing some cds: denon cd player ucd-77
It's not the cds that are the problem as they work in other cd players. Its seems to be the denon cd player itself that doesn't seem to be reading the cds.
Binap
Posted on Jan 31, 2008
chie-chie
  • 98 Answers
SOURCE: Cassette Player
  • very easy.. if your motor 12 v or 6 volts...for 12 volts motor buy an ic "kia 7812 this parts is voltage regulator with 12 volts 1a output..7806 this parts is volt.reg with volts 1a output..7803 3 volts output etc. etc.
  • input 1st terminal
  • ground mid terminal
  • output 3rt terminal
same a transistor.
Posted on Feb 05, 2008
c renner
  • 43 Answers
SOURCE: radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Posted on Mar 08, 2008
SOURCE: Kenwood KDC-2025 won't play CDs
hey it does not play mp3 discs. u need a regular disc. mathews
Posted on Apr 04, 2008
Cds play on all cd players but the ones i made on new computer do not why?
it all depends on the CD's your using. some CD's will not play on some players. try DVD-R blank disc, this may make a difference. try one to see ! I ran into the same problem a while ago! it depends on the player itself, DVD-R 4.7GB data 16xspeed. this should work if player is compatable with it.
Jan 23, 2012 | JVC Computers & Internet
My jvc cd player will not play the cd it says read & then no disk
the optical pickup (lens and laser) is dirty and needs cleaning. you can buy a **** cleaner and use it regularly, but if you need it too often, you'll want to take it apart to clean it.
Jul 24, 2009 | JVC Audio Players & Recorders
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
Tinny, hissy sound from mp3 files
not for sure here but I am a live sound eng. and in my line of work hissy and tinny say TO MUCH GAIN....tri setting the output of recording program or the computer settings a lil lower and make sure the HIGH END isnt CRANKED all the way up..
May 01, 2009 | Apple iTunes
I can not play cds, radio and tape ok but cd does not work i do not know what to do
you can try a cleaning disc , but it probably will not read that either so manually cleaning the laser lens would then need to be done , then if it still does not read there may be a problem with the focus on the lens or ,the laser is out , which then the laser mech. would need to be replaced.
Mar 14, 2009 | JVC KW-AVX800 CD Player
What buttons do i push for a music cd or anything to play?
I can send you a manual if needed. kb3xy@krbenson.com
Dec 12, 2008 | JVC XL-SV22 CD Player
JVC 5-Disc Player XL-F115
You won't get any sound unless you connect your CD player to an appropriate input on your amplifier (any but phono or tape/md) and connect your speakers to this amp.
Shout if you need more help.
Dec 30, 2007 | Audio Players & Recorders
126 people viewed this question
 Grubhead
Grubhead
