Question about Fitness Giant Sole Fitness F80 Folding Treadmill
Sole fitness treadmill circuit breaker will not reset
There is power going to treadmill but no power to display and circuit breaker will not reset
Wall breaker trips when power switch is flipped on
find the specification tag on the treadmill and note how many amps it draws...
Jan 16, 2018 | Sole Fitness Sole F63 Treadmill
Treadmill will not enter Factory Settings or Engineering mode. Can I reset the software? I spoke with Sole and they cannot help.
Idk how old your treadmill is but sole offers very good warranties on some parts even up to 5 years so maybe you can have them go out and repair it for you BUT from the sound of it they could not help you out so the only thing left is to do simple troubleshooting.
You can try just resetting the power switch, to off. Disconnect the power cord from the outlet and leave the machine be for about three minutes.
Reconnect and switch back on, then just Press and Hold the START, STOP, and ENTER key at the same time, until it displays "engineering mode" (it might say maintenance depending on the version) then just press the ENTER key.
If it works you can scroll through the menu with the SPEED UP and DOWN keys.
If it does not let you still, you might have an issue in your console and it needs replacing but it is not limited to just the console, there could also be an issue with a component on the Main Board (Circuit Board) or other electrical components.
Hope this helps!
Sadly we do not carry any sole products yet, but we would be happy to help you find a technician in your area to come out and help.
You can give us a call at 888-713-2880 or talk with us by chat at www.sportsmith.net Good luck on the repair :)
Aug 31, 2015 | Sole Fitness F63 Treadmill
I just put together a Sole f63 treadmill (it took forever). I turned the power button on and the display lit up. I pressed the start button and the display shut off. I can't get the display to turn back...
First of all, make SURE that the unit is NOT plugged into a ground fault circuit interrupt (GFCI) outlet. Make sure that the safety key (or safety tether cord's magnet) is on the round metal portion of the console control's head. (It will NOT operate without this in place because it's a safety feature. Also check the circuit breaker under the console, & push it in until it clicks (if it has been tripped (it would extend out if tripped)). Make sure that the power cord is fully inserted in the appropriate power outlet & that the building/home's circuit breaker has not tripped. Otherwise, call your dealer to replace what would be a defective treadmill.
Feb 22, 2015 | Exercise & Fitness
Why did my treadmill stop abruptly while in use?
Your assumption is correct, if you have a household circuit breaker popping, you have a short or over current situation. If you have too many other things plugged into the same circuit you could be overloading that breaker. Depending on how your home is wired, you could have a few (older homes may have quite a few) outlets feed by a single breaker. If you have used the treadmill in that outlet (with the same items plugged into that circuit), the breaker it's self MIGHT be going bad (popping at too low of current).
For safety, inspect the power cord, for any damage, and be replaced if there is any.
If the power core is undamaged, I would try plugging the treadmill in another circuit. Choose an outlet that was not affected when the breaker popped. It you use an extension cord to get to another outlet, be sure it's rated for enough current. If it still pops the same breaker it's the same circuit, and you need to plug it in somewhere else (probably in another room). If a different breaker pops, then the short in in your treadmill. At this point you will need to know something about electricity to further isolate the short.
May 19, 2014 | Endurance T3 Treadmill
Treadmill not working and alarm sound when plug in
Does the display give you an error code. I'm having a similar issue but all LEDs on my display are lit with a constant beep and still have not gotten resolved. Have you tested the power source and fuse and the reset circuit breaker. I am waiting on a new reset circuit breaker part to come in and hopefully this fixes the issue. I will let you know.
your posting is a year old have you since got the treadmill fixed and what was it
Mar 29, 2014 | Bremshey RN7 Folding Treadmill
No power
Check the reset/off circuit breaker located on the
treadmill frame near the power cord. If the switch
protrudes as shown, the circuit breaker has
tripped. To reset the circuit breaker, wait for five
minutes and then press the switch back in.
Mar 07, 2014 | Proform XT 70 Treadmill
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
I have a Proform 625 treadmill that I had to move. I unplugged the unit, slid it to where I needed it to go and plugged it back in. When I did so, the console powers on, but the display flickers and the...
You can try the following:
a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet (see page 9). Use only a single-outlet surge suppressor
that meets all of the specifications described on page 9. Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is fully inserted into the console.
c. Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
d. Check the on/off switch located on the treadmill near
the power cord. The switch must be in the on posi-
tion
Nov 25, 2013 | Proform 625 Front Roller Model Pftl62510
Fitness Giant Sole Fitness F80 Folding Treadmill Logo
346 people viewed this question
Top Fitness Giant Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Fitness Giant Exercise and Fitnes Expert? Answer questions, earn points and help others
