Question about Irons
Philips easycare 3232 needs cleaning and iv forgot how to do it
How do you clean it
    Problem Solver:
  • 9 Answers
Http://download.p4c.philips.com/files/g/gc3231_02/gc3231_02_dfu_ind.pdf
Posted on Sep 30, 2012
I run vinegar through my iron and iron on a white towel using the mist and spray to "work out" all the residue. Then I use plain water again to make sure I have removed all the dirt before ironing anything delicate.
Posted on Jan 04, 2009
Philips manual
You should clean your Philips Steam Iron. Follow the video guide given below to clean your iron
Aug 16, 2014 | Irons
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
How to clean the water tank of philips steam generator
Nowadays there are various services for doing such work .You can hire them.There are also leak detection services who can help you in finding the leakages,repairing pipes ,removing mold and cleaning the tank.So it is better to hire them and check your pipes while cleaning.
http://www.allkarepropertydryingout.co.uk/luton/leak-detection-services-london.html
Jul 19, 2012 | Irons
How do i clean my gc3531 iron
Hi e st clair...
I would use CLR to clean your iron.
Mix it according to the directions with distilled water.
Can be bought at Home Depot,Loews,Walgreens,CVS,Ace Hardware and many other places.
After cleaning rinse completely free of contaminated water with clean distilled water
Please take time to rate me
Sep 04, 2011 | Philips GC 3111 Iron
How do I clean the Baseplate
Good day!
The easiest way to clean the base plate of your electric iron is to use a sand paper (P200) p200 is the number of the sand paper that you need to use..
Scrub gently it in the base of iron until the real color of the metal is appear..If the color of the metal is appear it means the metal base plate is cleaned and ready to use..
Thank you and I hope this simple information help you..
Jun 17, 2011 | Philips Irons
My Philips steam iron Easy Care 3232 oozes brown liquid through holes when used on steam. How can I clean it?
Periodic Descaling of the iron will help reduce this.
Mineral deposits in the water will remain inside the iron after being converted to steam. This builds up over time as scales unless cleaned.
For descaling instruction, refer to manufacturer.
Aug 26, 2010 | Irons
How to clean a phillips gc 8320 steam iron
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Hi,<br />Here is a tip that will help you with that problem...<br /><br />Cleaning a Steam Iron Soleplate</span></div> <div class="solution-text"><span><br /><a href="http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate" target="_blank">http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate</a></span></div><span> <div class="solution-text"><br />Cleaning a Steam Iron White Scale and Brown Water</div> <div class="solution-text"></span> </div> <div class="solution-text"><span><a href="http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown">http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown</a><br />heatman101</span> </div><!-- /solution text --><!-- helpful bar -->
Aug 26, 2010 | Philips Irons
Cleaning Carezza soleplate of iron
Here is a tip that will help you with cleaning the sole plate of your iron...
heatman101
Jul 06, 2010 | Philips GC 8220 Iron
Irons Logo
500 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
