Question about Trademark Global Curling Iron Mitt Holder Set of 2
Can't locate replacement cable XY9603 for curling iron, in usa
Cable damaged
How to get Braun curling iron to heat?
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Aug 21, 2016 | Braun Irons
My tefal keeps tripping elcb in fuse board what could be wrong
Next time it happens and it trips.. use a dry towel to unplug kettle, just in case.
Is the base wet? Check the kettle for cracks. Check the cable. Is it damaged? Try replacing the fuse in the plug. Is the steam that the kettle produces affecting lighting or other electrical items around it? Try moving the kettle to a different location.
Aug 05, 2015 | Tefal Irons
I own a Wahl 5 Star Shaver and plugged in a non Wahl Charger cord into the device, heard a spark, and then unplugged it. I found the original Wahl charger cable, but the device won't charge; even after...
I'm afraid you blew up your shaver. Only if they build in any over voltage protection or a fuse it could be the damage is limited, but I think a engineer should look into the shaver, or perhaps you better buy a new one?
Jan 18, 2015 | Wahl 5 Star Shaver WA8061
How do I get the tv schedule for curling this fall and winter ????
Please next time use Google for this question. We can't find it here in Europe.
Oct 05, 2014 | Remington Instant Curls 1 1/4 Curling Iron
I have a Conair infinity pro curling iron it sucks
try a local hair salon i happen to have the same problem theres a treatment u can use befor ironing ur hair that helps with damage
Sep 28, 2014 | Irons
I need Instructions
look on the internet use the name and style they should show you something.
Jan 05, 2013 | Remington Style Solutions Ultimate Stylist...
Where can I get my Remington curling iron fixed?
Iguess you could take it to any local electrical store, but first you could contactthe Remington site and ask their advice. Here is a link for it http://www.remingtonproducts.com/womens/haircare/curlingirons.aspx
Jul 16, 2012 | Remington Instant Curls 1 1/4 Curling Iron
Trademark Global Curling Iron Mitt Holder Set of 2 Logo
123 people viewed this question
Top Trademark Global Irons Experts
Are you a Trademark Global Iron Expert? Answer questions, earn points and help others
