Question about GE PFS22SISSS Stainless Steel French Door Refrigerator
MY GFSS6KIX FREEZER GETS COLD BUT WILL NOT FREEZ
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: ge profile bottom freezer (model GFSS6KIX) not keeping freezer cold enough. Water under veggie drawers.
First, check the condenser coils for any lint and dirt buildup and see if the condenser fan is running fast.
Post back your results.
Posted on Nov 05, 2012
Keeps running water and wont make ice
Ice Maker does not make ice; it takes water in and the cold freezer temperature causes the water to freez. Check your freezer temperature and overall performance of the refrigirator.
Oct 19, 2015 | Refrigerators
Ge profile bottom freezer (model GFSS6KIX) not keeping freezer cold enough. Water under veggie drawers.
Nov 04, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
How do I remove the light bulbs from Gfss6kix
Press Accept or replay
I have a solution for this
Bruce
Jan 14, 2011 | GE GFSF6KEX (2585 cu ft) Bottom Freezer...
I have an AHT Salzburg chest freezer and it's stuck in "chilling" mode and not getting cold enough to freeze anything. It's a commercial freezer and says it has chilling and freezing modes but how do I get...
pull the plug and let it defrost. ck the drain for water. it maybe pluged. after 2 to 4 hrs. plug it back in and set the temp. to -10 degrees f . fill small dish or bowl with water and see how long it take to freez. if it takes longer then 4 hrs you may need freon or have a compreesor problem, or defrost timer .
Aug 23, 2010 | True 31 cu. ft. / 878 liter Commercial...
Freezer will not freez ,warm air
replace temp sensor, should work also first check drain pipe some time gets blocked.same symptoms...
Feb 07, 2010 | Refrigerators
Refrigerator does not get cold. The freezer works fine, but the fridge only gets slightly cool.
normaly the fridge has its own thermostat to keep the tem right, if this thermostat has stoped working it will do one of two things,,, freez every thing up as it wont turn off the compressor or will just stop working as it wont turn on the compressor,,, try turning up the thermostat first,
Nov 19, 2009 | Hotpoint Refrigerators
Refrigerator cooling fan freez so not cooling.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gf
Dec 27, 2008 | Nokia 3230 Cellular Phone
I have a fridge freezer in the garage will not freez cuold it be the anbeant temp too low
no. temp is determined by the temp inside the fridge. if its on and running but not cooling its probably low on gas . if its not cooling enough and off its probably the stat. i doubt the garage gets cold enough to be a factor at all. good luck
Dec 07, 2008 | Refrigerators
Refrigerator side want stay cold
sonnds like your control board is going out .and possibly your cold control.
Feb 27, 2008 | Refrigerators
GE PFS22SISSS Stainless Steel French Door Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
