Question about Sansui SLED2280 22 in. LCD TV
How to reprogram can not get any chanels - Sansui SLED2280 22 in. LCD TV
  • 127 Answers
Go to source select tuner antena/cable select search chanels.
Posted on Nov 03, 2012
How do i reprogram tv chanels
Check your manual for instructions.
Jun 15, 2015 | Televison & Video
Orion tv model 1933 only 34 and aux
change your memory ic ( 8 pin ic ) or" reprogram your memory ic.channel store problem solve 100%.
May 29, 2012 | Orion1934 19" TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
My samsung lcd tv is lock on tv channels only
reprogram all the chanels, go to set up then auto program,after you finish sort the desired channels,or you can store it manually
May 14, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
The remote for the hughes sd-dvr40 will only change the tv chanel even with the button on the remote in the sat. mode it will not change the sat. rec. chanels
I fixed it by reprograming the remote. This is how! Point the remote away from the DVR and press and hold the TV power button and the Directv button on the remote at the same time until the red light at the end of the remote comes on and stays on when you release the buttons. Then press the thumbs down button on the remote (3) three times and press enter on the remote. This corrected my problem which set the remote as a new remote. You will have to reporgam your TV code into the remote to operate the volume on your TV .
Nov 16, 2009 | Hughes SD-DVR40 210-Hours Video Recorder
I HAVE 2 MOTOROLA RADIO' S MODEL# EX500 THAT ONLY TALK TO EACHOTH
Assuming you have checked all the channels for functionality, it appears your radios need reprogrammed. This is something which would require you taking the radios to your local Motorola dealer.
Jan 23, 2009 | Motorola Radio Communications
PROBEM WITH MY Durabrand TV DU2701
Go into your menu of the tv and reprogram the channels into the tv. Use "autoprogram" it will be in the menu somewhere.
Nov 09, 2008 | Durabrand DWT2704 TV
MY RADIO
This radio needs to be reprogrammed with the Motorola programming software, this procedures needs to be made by a technitian or someone that has the software, programming cables and the knolagement and the frequencies of course, also the radio has to be the same band of the police.
Oct 26, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Sansui SLED2280 22 in. LCD TV Logo
79 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
