Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Frigidaire Gallery Washing Machine Mod. GLWS1349ASI - gunk/mold
This gray-colored gunk is coming up from the base of the agitator. How do I remove the agitator to inspect under the base and drain? Machine was manufactured 04/02. Please advise.
5 Suggested Answers
futureloginn
  • 734 Answers
SOURCE: Hot water not going into washing machine
hi there,
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Posted on Dec 12, 2008
SOURCE: Main Drum Bearing
Rear Main Bearing is bad, Believe you have replace whole back of the drum, about 200$
Posted on Apr 02, 2009
SOURCE: how do I get the black mold off the rubber seal
Try this! Points 10, 11 12 particularly helpful...
http://www.letsfixit.co.uk/html/washing_machine_hints.html
Posted on Jun 17, 2009
nothnagel
  • 20 Answers
SOURCE: frigidaire gallery top load washer glws1349asi
The clutch may need to be replaced. Look for soot or dark deposits on the floor beneath the machine. Otherwise, it's time to replace the little plastic drive coupler between the motor and the transmission, that would cost about $20 if you do it yourself. Here are a couple sites with helpful guides:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0pt 5.4pt 0pt 5.4pt; mso-para-margin:0pt; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.repairclinic.com
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0pt 5.4pt 0pt 5.4pt; mso-para-margin:0pt; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.applianceaid.com
Posted on Oct 22, 2009
How many cubic ft. in a 2001 Frigidaire Galley model #FWT647GHS washing machine
Hello friend, that's a great question!
I understand you would like to know the cubic footage of your Frigidaire washer. Based off the model number you have provided your washer appears to be a 4.4 cubic feet washer. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Washing Machines
Rusted agitator mounting bolt in frigidaire washing machine
Pour some oil on it, engine oil or AT oil will do, kitchen oil too but, becareful of colors so after you done with the cleaning, wipe the excess. Remember, since the bolts are rusted they require extra strenght hence get a tool that completely covers the bolt or else you will grind the corners of the bolt.
Hope this helps
Nov 28, 2013 | Frigidaire Washing Machines
I am seeing a line of **** at the top of the drum even if I use bleach on my whites they are turning brown my dark colors have gray color **** on them is the washer too old?
There is a shaft seal under the agitator that may be leaking greasey oil.If your aagitator wiggles at the top .Or take off the agitator and look
Sep 22, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
How do you remove the gyrator from a frigidaire gallery top load washer
Pull the top piece off. Remove the bolt underneath the top cover.
Pull up on the agitator to get it off.
Sep 07, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire gallery top load washer glws1349asi washes but won't spin. sounds like motor is running but nothing is spinning also a burning smell
Oct 22, 2009 | Frigidaire Washing Machines
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Removing the agitator
Pull the top of the agitator off...there is a nut inside of it (ratchet and socket usually 5/8 and a long extension) pull agitator out.
Nov 18, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
171 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
