Question about Samsung LN32C350 32 in. TV
Picture brightens then darkens
Sometimes can turn on tv and work fine for hours, sometimes turn it on and after a few minutes the picture becomes bright white then after a minute or so turns black with purple around the edges. Sound is normal Had tv over a year now. Also when going to video options to try to change the brightness or darkness it suddenly becomes dark.
  • 1 more comment
  • Brian Wade
    Brian Wade Nov 05, 2012
    I talked to Samsung and tryed resetting the picture and unplugging it,& waiting
  • Brian Wade
    Samsung said it needs to be serviced but try unhook the cable and just watch dvds or video games and see if it works still.
  • Brian Wade
    tried not tryed
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Trying with a DVD will rule the tuners in the set in or out and also suggest a setting in the set or a box if used is causing this issue.
Posted on Nov 06, 2012
lukster
  • 217 Answers
SOURCE: plasma tv
ned to adjust the VS-voltage or the VSCAN-voltage
Posted on Jul 20, 2008
  • 304 Answers
SOURCE: Dark colors fade too dark, become almost
Replace the Main bd.
Posted on Apr 16, 2010
  • 304 Answers
SOURCE: within the past two months, the video will go
Either the T-Con bd or the Main bd is going bad. Start with the T-Con bd first.
  • 132 Answers
SOURCE: When I turn on the tv, the left side of the screen
It sounds like you have a bad slave inverter board. I've fixed a few of them with the same problem and it's always been this board. With the back off of the tv, it will be the board located all the way to the end where the problem is. It will have several wires going from it to the screen. You will probably have to get the part number off of the board to be able to find one, as I couldn't find one by using that model number.
Posted on Sep 02, 2010
budmrtn
  • 11361 Answers
SOURCE: when i turned the tv
Youy may have bad T-CON, Power supply, LCD panel.
Learn about T-CON/LCD panel failure mode:
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
PDF download: http://www.mediafire.com/?zzjygannjty
Inside the TV:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20LN-S3251D/
Try this when the screen goes black:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 10, 2011
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
LG CRT TV, picture becomes yellowish
yes it is due to dry solder in vedeo driver section(a board fixed to the pict-tube.).
Jan 22, 2010 | Televison & Video
Picture goes bad (fuzzy&scrolls&lines) on Hitachi projection tv
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 14, 2017 | Hitachi 50UX57B 50" Rear Projection...
DLP tv trouble shooting
Try and clean the filters or the plastic fan guards.
Jul 30, 2008 | Home Security
Frozen screen
sounds like the digital main board
Jul 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Hi.
Yes it could be a cooling problem, If your tv has any filters remove & clean them ensure fan can turn freely & that nothing can or is snagging it.
http://dysonmanuals.inc.io/
Chris.
Nov 09, 2007 | Televison & Video
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
Samsung LN32C350 32 in. TV Logo
168 people viewed this question
Henry  Thomas
Henry Thomas
