Question about Vacuums
Bissell Spotbot hose needs removed and cleaned
My spotbot suction is greatly reduced. My hose is extremely dirty and I think it needs cleaned. Does any one know how to remove the hose? There appear to be 2 buttons holding it into place, but they do not move.
I have unscrewed the unit and pulled the top off, but still can not see a way to remove the hose.
SOURCE: Trouble with Spotbot
Just found out that the Bot I gave my daughter for Christmas LAST year didn't spray either - almost a year and she's never used it (and didn't let me know). Got them for two other daughters - those worked fine. I was pretty skeptical, but I tried the solutions above (holding down trigger in manual mode - and also removing and resetting the tank several times even though I didn't see bubbles). Voila - another success story. Have two daughters' bots going on MY carpet now - hmmm...why didn't I buy one for myself?
Posted on Dec 07, 2007
  • 556 Answers
SOURCE: User guide
You will need Adobe Reader to read/print these manuals
Use the following link and click Get Adobe Reader
http://www.adobe.com
There appear to be two models the user guides are in the right column -- be sure the models are right the model numbers 1200-a and 1200-B appear under specs
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=spotbot+1200
Posted on Dec 22, 2007
SOURCE: Spotbot is leaking...
either the "duck valve" on the dirty water tank or the clean water tank valve (in the screw top) are leaking. you can buy either or both from bissell for a few bucks.
Posted on Jan 07, 2008
reddevil6
  • 1673 Answers
SOURCE: Within an Hour my SpotBot stopped working
Some of that water must have gotten inside amd shorted something. If this is less then 1 year, it would be under warranty. It iwll have to be taken apart and checked.
Posted on Feb 14, 2008
SOURCE: SpotBot: Brushed do not rotate
I have the same problem. I took the thing apart and tested the motor and it works just fine. The voltometer is telling me that there is no juice going to the motor. I tested the voltometer on other contacts in the vacuum and it's working fine. It seems every moving thing in the spotbot runs on 120v AC 60mhz, but like I said above; for some reason the spot bot isn't sending any electricity to the motor that makes the bristles go around. It has to be a controll board problem as the wires go strait from the board to the motor. Personally, I'm not even going to bother getting it fixed. I'll just stick with the hand cleaning tool. The darn automated cleaning cycles use too much solution anyway.
Posted on Oct 01, 2008
Tip
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
SPOT BOT NO SUCTION
Hey Courtney! Sorry to hear about the suction problem on your SpotBot. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1040&cid=ccsocial
Jan 04, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
Clean bissell spot bot brush
NONE of these answers apply to the question! The asker referred to the Bissell SPOTBOT, which doesn't have a push handle. I'd like to know how to remove the brush myself. I know how to remove the components but haven't been able to figure out how to remove the mechanism.
Mar 12, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
It is leaking water from the bottom
I had this problem, and after some research found out I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
I purchased this gasket from Bissell for 1.39 and the suction is night and day. No more leaks. I purchased my SpotBot Bissell new at Target, so I have no idea where the black gasket went.
Jul 07, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell spotbot: leaking the dirty water from bottom. I took the bottom plate off and there is a really crappy rubber seal. I think it is leaking from there.
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Sep 07, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Mine constantly leaked as well but I found that if I remove the container will the solution in it after every use it doesn't leak anymore. I store my container (upright - nozzle face up) under the sink with my other cleaning products and when I need to use the machine I pull it back out, pop it in and clean.
HTH
Dec 28, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Vacuums Logo
109 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
