Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
I have a hayward SR333Lp that ignites for 5 seconds and then displays service heater. No leds on back of board to indicate cause
The system runs for about 30 seconds- fires for 5, igniter quits, Servie heater light comes on and it shuts down in about 45 seconds.
  • dmurray318
    dmurray318 Nov 05, 2012
    Actually it is a sta-rite Heater...sorry for the confusion
    Champion:
  • 246 Answers
Any codes?
Many thing can be bad
Posted on Dec 03, 2014
  • 5,245 Answers
Today's gas appliances are designed to shut off when combustion problem is detected.
For example if burner parts are dirty of clogged, the gas valve continues releasing gas, but not all the gas is burned.
This caused potential explosion risk, with unburned gas in the combustion chamber and flueway.
Call service tech to clean combustion parts, check pilot or igniter alignment, check gas control valve, and gas pressure, and bleed air out of gas line if needed.
Search internet for product manual. Product number appears on label, and then add .pdf to search parameter.
Posted on Nov 05, 2012
SR333LP pool heater continuously cycles ON/OFF, the fan stays on
The age and over all condition of the heater would help. Try removing the Thermal Reg and see if it smooths out. If the heater responds, replace the Thermal Reg with a new one.
Jun 11, 2017 | Sta Rite Sta-Rite Max-E-Therm High...
Hayward Heater H series 400 BTU will not start
This is a normal display when heater is being controlled by a remote thermostat. No service is required. If heater is not being controlled by remote thermostat, change setting by using the MODE key to put the heater into STANDBY. Press and hold the DOWN key and then press and hold the MODE key. HOLD down both keys for 3 seconds until the indication "bo" is removed from the display.
The key to this is DOWN first and then together with MODE, both for 3 seconds.
Make sure the display is not showing "BD".
Jul 06, 2017 | Hayward H Series Pool & Spa Heater 400k...
New Hayward Heater H series 400 BTU won`t light error IF
check gas pressure again meter could be too small if furnace goes on while heater is on it will run out of gas and turn off giving you that error
May 13, 2012 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400FD. Can't adjust temperature.
need new display board also check if connected to a system disconnect and try alone
Jan 28, 2012 | Hayward H400FDN Low NOx Natural Gas Pool...
Heater was running and displayed ce code then it went to displaying water temp then stopped running and no display or lights on at all on the panel
There could be multiple things that could cause no lights to be on the panel and here are some of them, defective panel board, now power being supplied to the heater, defective power supply, etc. One way to resolve this issue is to get a schematic, volt/ohm meter and use it to make sure power is getting to the panel. If power is getting to the panel board then it is most likely defective. If there is no power getting to the panel board then you will probably need to call the Hayward technical support at 908-355-7995 and they should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward H Series Pool & Spa Heater 400k...
Error code "CE" is being displayed. I was told to replace the control board, which I did. Still getting the error message. Does the system need to be restarted to recognize the new board? If so,...
Error code "CE" is "Communication Error" the manual for your heater gives the following description.. "If communication between the ignition board and the display board is not established within 3 s of power-up an error will be displayed. After communication is established, if it is lost for 30 s, the error will be displayed. The error code will be cleared upon a valid data exchange between boards.
That being said If you replaced the board I would check all your connections closely and look for bent pins, corroded/oxidized connectors, etc. If this still does not help give Hayward a call, they usually give pretty good support. You can reach them at 908-351-5400
Sep 19, 2010 | Hayward HSeries Natural Gas Pool Heaters...
Pool heater gas fire lights up and turns off 10 secs later
Assuming you don't hear any banging noises, that cycle is by design. There is a fault. 2 possible causes are the ignition board is bad, or the ignition sensor is not returning a voltage indicating the flame is lit. Take this out and put the ignition piece on your stove flame. Check for voltage while on flame (DC millivolt setting on multimeter). Put one probe on ground other on sensor lead. If it doesnt have voltage this is bad. If you do, its possible your board is bad.
Apr 26, 2010 | Hayward H Series Induced Draft Abg 100,000...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
I have a SR333LP poolheater will not turn on
Those are not service codes. Turn top over and look at the circuit board to see what light is lit
May 17, 2009 | Pentair MAXITHERM 333K BTU PROPANE GAS...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
217 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
