Question about Samsung LN37A550P LCD TV
Picture not right wont adjust
  • Tony Nov 03, 2012
    What do you need to adjust?
Picture is too wide to fit screen can not see complete picture
hi there, i don't know your TV brand but this could be of help anyway. there is an adjustment for horizontal and vertical width. you can manually adjust the setting until it fits the picture on the screen. for standard TV it has trimmer in the CRT board. If in your case you have a soft adjustment in the remote control try to adjust it. Learn how the menu works just look for the picture adjustment.
Good luck, please rate and vote.
Mar 20, 2011 | Televison & Video
I bought new monitor Compaq S1922a and picture stretched horizontal. I have HP intel with Vista. How to adjust VGA to make picture normal?
if the whole image is too long you can adjust it from tthe image driver ..it will be in the right side on the task bar near the programs that are opened all the time ..and named like the video card you are using and usually will display when hoovering the resolution in use..open the resolutions and choose one that fits best...and confirm ..
To adjust just the the picture from the desktop ..right click on the desktop..properties..and desktop...in there choose the desktop image ..or change image ..and you will have 3 possibilities for adjusting the picture to fit..center ...stretch..and tile.. see them one by one ...if non of the stile will make it visible in a normal way ..then you should change the picture,,and choose a wallpaper that it is in the same form and big enough to fit....
T change a picture on the wallpaper it is enough to right click on it when its opened ..and choose it to be set as wallpaper from the list of tasks...
May 31, 2010 | Computers & Internet
I want to change the picture size to wide screen and when i do the picture goes off the screen and i cant seem to get it just right please help me :)
What type of connection are you using? Is it a VGA cable? You TV should have a function called Auto Adjust. It will adjust the picture to the borders automatically. Check if you have that. If not, your TV should at least have options to adjust the picture position yourself. Just like a computer monitor screen where there are buttons on it to adjust the picture.
If your TV is a Vizio, I can guarantee what I said, I own one.
Apr 02, 2010 | Samsung LN-T4665F 46 in. LCD Television
When i switch my tv on. I can hera the volume but no picture. Then the tv switches off and restarts until both the volume and picture is working. This could take up to an hour
yes. tv has a circuit which controls current to the red, green, and blue piture tubes. you wont get picture until they are balanced. adjust the screen controls until it comes on faster. it should only take maximum 20 seconds for a picture. gaurantee it will fix it. adjust the screen control
Nov 09, 2009 | Toshiba Televison & Video
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Sound no picture
those are the screen adjustment controls, most likely they are turned down to low so the tubes wont power up. What happens is when you adjust them the set will continue to operate then when its turned off say overnight the tubes wont come on cause they are set to low, Try turning each of the 3 dials up just a little at a time equally untill the tubes turn on.
Feb 01, 2009 | Televison & Video
Problem with Picture
pin problem it wont adjust untill pin amp circuit is repaired
Apr 01, 2008 | Televison & Video
Covergence and Bowed Picture Problem
can you adjust any color of convergence in user menu blue, or red up or down left or right. if you can make any up or down left or right adjustments on any color then the likelihood it wont be a convergence ic. it would be a output resistor. so see if you can get any movement. with it being bowed i was suspect an convergence ic.
Jan 08, 2008 | RCA P60920BL 60" Rear Projection...
Open Questions:
See all Samsung LN37A550P LCD TV Questions
Samsung LN37A550P LCD TV Logo
23 people viewed this question
Jerry Greenberg
Jerry Greenberg
