Question about Miele Novotronic Premier 500 Front Load Washer
Miele novotronic w 833
Funny noises, does not sentrifugate properly
    Sergeant:
  • 264 Answers
It sounds like your pump needs cleaning out
Posted on Nov 03, 2012
reverendrave
  • 24 Answers
SOURCE: replace door seal miele novotonic w 502
Hello mc2739,
It's been awhile for me since I have done this so I searched on the internet and found the following. The instructions are pretty detailed. You may want to contact Miele if any problems
1. Open the machine door.
2. Turn the main power off and unplug the machine from the wall.
3. Completely remove the powder dispenser drawer (it will come out so far (and stop), then there is a small button at the rear of the dispenser which you need to depress to remove it fully, you'll see this button once you've withdrawn the drawer to its stop position.
5. Undo and remove the 3 x hexagonal head bolts surrounding the door seal (they are at approximately the 2, 6 and 10 o'clock positions). Note these bolts actually secure the front panel to the machine chassis, they do not retain the door seal. Don't worry the front will not drop off.
6. Now look at the aperture of the powder dispenser drawer (you have of course removed the actual drawer earlier). Locate the lower left hand corner of the aperture, and you'll see a recessed philips head screw in a hole. Undo and remove that screw.
7. Now, you'll need to get on your hands and knees. You DO NOT need to tilt, or lift up the washing machine to do the next bit. Locate the underside of the front panel right at the bottom. You'll notice that it sticks out about half an inch or so and is proud of what I would call the kick plate which extends right down to the floor. You need to look on the underside of the front panel, about an inch or so in from the left hand edge. There you will see a spring loaded clip which when closed is located within a slot on the underside of the front panel. Using a flat bladed screwdriver, you need to carefully lever the spring clip open whilst gently pulling the whole front panel (from the left side) ajar. It will just suddenly pop out once you've done it.
8. Open the pump access door lower left hand side of the front panel) and unclip the drain tube from its plastic retaining clip.
9. Now carefully swing open the whole front panel, it opens like a door (hinged on the right hand side). It might be a little stiff as there are a whost of leads attached to it, but it is designed to open fully (with the leads attached) to about 90 degrees.
10. Next, unseat the rubber door seal from around the door opening area (on the chassis, not the front panel, obvioulsy), so that the seal the flops away from the chassis and lies just inside the machine.
11. You will notice that there is a thin steel band holding the door seal in place around the drum. On the right hand side (at about the 3 o'clock position), you'ss see a tensioning screw for the band. With a flat bladed screwdriver undo this completely and remove the screw (it is accessible from above with a long screwdriver). Be aware that there is 1 x washer and 1 x 'nut' type fitting that will fall out when you remove the screw. Locate these and retain them for later.
12. Now extend the steel band to its maximum opening (by moving the 2 x lugs apart where the now removed screw was).
13. You can now remove the steel band. Then pull it out through the hole/door aperture in the chassis.
14. Locate the small rubber tag at about the 12 o'clock position where the seal is attached to the drum and tug it. The seal will then come away from the drum. Remove the old seal completely.
15. Using your new seal, place this correctly around the drum (there is a lip on the seal and this has to go over the lip on the drum. Remember, the seal goes on the OUTSIDE of the drum. Ensure the 'tag' is at the 12 o'clock position.
16. Reassembly is then the reverse of removal.
17. Make sure that you do up the retaining steel band sufficiently and that you correctly locate the sela on the chassis front panel (there is a groove in the seal which will locate the seal in the aperture).
18. Finally, once you're done, put the machine through a few rinse cycles (where the water level is high) and look for leaks. If you have a leak, it is likely that your door seal has a rip/tear, or that it has not been correctly located around the drum - in which case you'll need to investigate.
Posted on Sep 17, 2009
Gallois
SOURCE: Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Posted on Sep 09, 2009
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
Macmarkus
  • 2605 Answers
SOURCE: Miele Novotronic W828 Water Control System Front Load Washer
Hello Ellen, welcome to fixya. I would begin by removing the rear panel and checking the belt and insure the basket pulley isn't loose as well. If the belt is in tack ( not broke ) but has come off that sometimes is caused by a loose or bent pulley, hence the suggestion to check the pulley. If the belt is broke, it may simply be a matter of normal "wear & tear" and just time to replace it. Hope that helps point you in the right direction. Please take a moment and rate this info according to it's helpfulness or let me know if I can assist you further. Thanks for visiting "fixya" today and good luck. Macmarkus :)
Posted on Jun 03, 2010
  • 177 Answers
SOURCE: Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Posted on Jun 14, 2010
Testimonial: "Thank you!"
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Bad noise starts when drying miele T560C
Idler pulley drum baring glides and a good cleaning
Dec 03, 2013 | Miele Novotronic T220 Electric Dryer
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Miele Novotronic W 832 washer won't turn on. It suddenly turned off after trying to open the door and now it won't turn back on. I tried switchinging powersources, didn't work.
Make sure the door is properly closed!!! The door opener is electric, and the electrics are turned off unless the door is properly closed, hence with the door closed but not fully "home" you will neither be able to re-open the door nor wash what is in the machine. Just give the door a firm push closed and it should spring to life.
Apr 27, 2011 | Miele Novotronic Premier 500 Front Load...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
hi,
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Miele T220 Novotronic
Miele is a top notch machine. Try checking your vent hose. It may be blocked in some way.
Jan 28, 2009 | Miele Novotronic T220 Electric Dryer
Miele Novotronic Premier 500 Front Load Washer Logo
344 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
