Question about PANDIGITAL 8.0" Digital Photo Frame (PAN802)
Unit won't operate on Schedule!
Set unit to operate unisng on/off schedule, will not work. Tried several different times etc.
  • 1 more comment
  • Anonymous Jan 05, 2009
    Should power be set off or on?
  • Anonymous Jan 16, 2009
    Unit will not operate on the schedule. The unit keeps turning off after about an hour, even when the scheduler is not on
  • Anonymous May 24, 2009
    The auto on/off feature does not work properly. Power is always on, time and schedule set correctly but the unit will turn on automatically at randon times and sometimes on the scheduled times. This is the second unit I have tried and have the identical problem with both. Reset to factoy settongs and reprogramming does not solve the problem. Any suggestions?
  • 423 Answers
Hi there.
1. The unit will not operate on a schedule of you have not set the internal clock. Refer to your manual to set this.
2. Yes you must have the unit kept on.
3. Remember: any user operations for example, pressing the remote keys, or removing or adding a memory card will cancel the schedule.
Hope that helps. Thanks for coming to FixYa and if there is anything else I can do, let me know. And don't forget to rate my solution.
Rob
Posted on Feb 21, 2009
Thermostat is following a schedule when none is set
Your Lennox thermostat could be defective, but it may have been programmed by some inadvertent button pushing. The thermostat also has certain default settings such as a low limit that will trigger heating if the indoor temperature becomes too low (to prevent freezing of pipes).
Feb 09, 2014 | Heating & Cooling
Cannot download TV Guide schedule-Verizon FIOS
With this problem I will suggest you to contact Verizon or motorola so they can help you better with this concern this is the number 1-877-466-8646....
Hope that helps.........
Sep 15, 2008 | Panasonic DMR-E85H DVD Recorder
Tip
Schedule the recording while record streaming music from internet
Tips on schedule the recording while record streaming music from internet
Then found a tool named streaming audio recorder. It can schedule you recording as below.
1. set the "Starting time"
2. Set the "Duration" time.
3. After recording, help you turn off the computer.
i am not sure this can help you .
it supports all popular streaming media protocols, HTTP, RTSP, MMS, MMSU, MMST, etc.
on Dec 29, 2008 | Apple Streaming Networks PMR-100 iRecord...
Control system to operate 2 different sprinkers with alternate operation times.
Set the first alternating watering schedule in the "A" Program and the opposing alternate watering schedule in the "B" Program.
Sep 15, 2013 | Garden
My Honeywell Thermostat won't stay at the temp that I set it at!
You are likely running a schedule. When you go to tstat and change the temp it is a temporary setting that will expire in a given amount of time. 1, 2 3 hours etc. "HOLD" can sometimes bypass the schedule, "RUN" returns to the schedule. Not sure what model tstat you have but you have to exit your schedule.
Apr 18, 2017 | Honeywell Heating & Cooling
I have an automatic pet feeder. The digital timer that came with the feeder has malfunctioned and was no longer able to display times, etc. I have purchased 2 different digital timers @ Menards. First...
there is a 1-800 number that comes with these products for tech support,i am a master electrician and it could be the unit itself and not the timer
Jun 12, 2011 | Hardware & Accessories
New intermatic timer installed. I can turn on manually and it will turn off at designated time but will not prgress to turn on automatically.
If display shows, and timer turns lights on-off with manual override, then timer is wired correctly, and battery is good.
If timer will not turn ON at scheduled time, but turns OFF correctly, then best suspect is the programming.
Open following link for ST01C programming steps.
http://waterheatertimer.org/ST01C-program.html
Program1 is ON
Program2 is OFF
Program3 is ON
Program4 is OFF, etc
Review your schedule: Press Mode button until PGM starts flashing, and then press ON-OFF button until 01 starts flashing.
If Program1 cannot be set for some reason, then set your ON schedule on Program3 and ignore Program1. The timer does not mind if you have OFF set on Program2 and ON set on Program3 or Program5 or Program7 etc.
If you have multiple programs, for example different ON-OFF times for each day, then check for scheduling conflicts that will cause timer not to function as expected.
If timer is defective, contact seller about 1-year warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Since the time change I can't reset my clock. It
If your clock radio is more than two years years old it will be operating on the old changeover schedule, and there's no way that you can change the schedule. What you can do though, is turn the DST switch (if so equipped) to the OFF position and change the time manually. If yours is an "atomic" clock you can force the change by setting the clock to a different time zone. (I have an atomic clock that's set up on the old schedule. DST is OFF, and I change the zone between the Central and Eastern time zones.)
Bill B
Apr 02, 2010 | Emerson SmartSet CKS1850 Clock Radio
Panasonic DMR-ES40V VCR won't schedule record: Recently, the VCR will not do scheduled recording anything beyond today. I can schedule a recording and it appears OK (I get red light on panel), but I never...
I found this solution on one of your old notes (but a different machine). I set up a scheduled record for 11:59 PM to 12:01 AM for the current day, then set up the scheduled record for the next day. The VCR recorded both the initial 2 minute session and the later one which I wanted to record.
Dec 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
PANDIGITAL 8.0" Digital Photo Frame (PAN802) Logo
282 people viewed this question
Top PANDIGITAL Photography Experts
LP
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
