Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm drum will not operate, under any cycle?
Does power up, drum will not turn under operation settings. The drum does turn by hand, does not seem to be mechanical issue.
  • Charles Stone Nov 03, 2012
    I will check it out Thanks!
    Sergeant:
  • 264 Answers
Sounds like your brushes are gone mate
Posted on Nov 03, 2012
  • 10 Answers
SOURCE: Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Posted on Feb 12, 2008
  • 958 Answers
SOURCE: washing machine drum won't turn under power
is the washing machine went to its usual cycle? put water in?
if you think the motor should have run already, then it could be the motor or the motor inverter.
check the motor leads for equal resistance, if i'm right, you may have a three phase motro so the three leads that comes out should have equal resistance.
also, if you can monitor the voltage present in the motor leads while it is plug in and you are waiting for the motor to run, if there is voltage then there is a problem with the motor, if there is no voltage present, then the inverter unit would be the defective part.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
SOURCE: drum does not spin
We have an LG TROMM with the same problem, 3 years old as well. We bought the extended warranty (Huge waste of $$$$).  So far they have determined it is not the motor or either of the control boards.  We think it might be a relay switch or possibly the brake.  Good luck with yours, we just went out and bought a new washer.
Posted on Jul 03, 2009
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
My lg tromm washer sudenly started making a grinding sound and the drum does not spin. What is wrong?
You don't say whether the drum turns freely by hand.
It could be a broken spider or a seized or broken bearing or something come adrift in the tub causing it to jam.
The top will need to be removed for a closer inspection and it might be a simple and quick repair but from your description it will probably be absent from your home for a day or three and cost quite a lot.
Mar 01, 2015 | LG Tromm Front Load Washer And Dryer Set
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 | Dryers
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Apr 13, 2010 | LG WM1814CW Front Load Washer
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
Drum does not spin
Jun 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
46 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
