Question about Sony VAIO VGN-FS660 Notebook
Screen will not come on
Also gets hot
  • Sony Master
  • 7,627 Answers
AT boot the screen doesn't come on? If it's hot, remove all media, CD's DVD's USB, etc, turn it off , unplug, remove battery, let it cool off and replace battery, plug in, reboot. Is there any change?
Posted on Nov 03, 2012
No hot water getting into Estate topload washer. Have to turn off cold tap completely to get hot washer for wash cycle. Then turn cold tap back on for rinse cycle.
One simple thing to try is to clean them screens on the water valve. Remove the hoses and get the screens out. Give em a clean or chunk em and wash on!
Oct 30, 2011 | Estate ETW4400VQ Top Load Washer
Where is the filter located and how often do you have to clean it?
Most washers have screen filters where the hot and cold water lines connect. The condition of your water supply would indicate how often you clean these screens. If you notice a decrease in water flow into the tub you should clean the screens.
Shut off the hot and cold water supply lines.
Drain the pressure from the lines by turning the timer dial through the fill cycle in both hot and cold water modes.
Remove the hot and cold water lines from the back of the washer.
Look for a screen inside the hose coupling or the washer inlet.
Remove screen and clean using a wire brush. If screen is damaged get a replacement at a hardware, or home improvement store.
Jul 20, 2011 | Washing Machines
My mp3 player screen went black, it is getting hot on the inside, and when i press the power button and press it to play, i get a repeating noise. computer will not recognize it. and screen stays black,...
my mp3 player screen went black, it is getting hot on the inside, and when i press the power button and press it to play, i get a repeating noise. computer will not recognize it. and screen stays black, what is wrong
Jul 08, 2010 | Philips SA3025/37 Flash MP3 Player
Kenmore 80 series washing machine - cannot get
Hi and welcome to FixYa. I am Kelly. This sounds like either the hose or the water inlet valve screen is clogged. Possibly the pinhole inthe diaphram itself of the water valve. Here is what you can do.
1. Get a bucket
2. Turn off BOTH water valves at the wall.
3. Remove the HOT water connection at the water valve. Then check the inlet screen for debris. You can remove the screen from the water valve by using a knife blade on the very outside edge of the screen tugging outward. Hold the screen up to the light check it for debris. If it is dirty wash it under a light flow of water in the sink. DO NOT reinstall just screen just yet.
4. Use a measuring cup or something similar to catch water at the water valve HOT connection. Select a WARM wash cycle and start the wash cycle. Let the water flow into what ever it is you use to catch the water exiting the HOT water connection.
Tap on the cold water hose connection to try and free the debris inside the water valve as the water is flowing. Do this a few times until you have let water back flow through the water valve for about 20 seconds.
Machine timer off.
5. Reinstall the inlet screen in the water valve and reconnect the hose. Place the HOT water hose in the bucket and start the WARM fill cycle again. This will flush the hose.
Machine timer off.
6. Reconnect the hose at the wall connection and turn on the water at the wall.
7. Select HOT wash and test water flow. It should by now be (fingers crossed) flowing.
You can repeat the above for the cold water side if you need to.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
Bottom right corner of the LCD screen is very hot
I would first search the internet and Dells website to see if there is a recall on this item. If there is, they will replace for free.
Changing the inverter in screens always seems to complicate the LCD. I prefer to just purchase a new screen and everything works great. I replaced an inverter on a couple and had to change them again and again do to them slipping.
Replacing the screen is a bit more expensive but will save you time and money in the long run.
Oct 03, 2009 | Dell InspironTM 1501 Notebook
Natural gas dryer running too hot
I suspect you have a blocked air vent. A blocked vent will make you dryer run hot. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Did I get riped off
How hot. LCD screens get alot hotter than CRT or old tv screens
May 24, 2009 | Sony 32 in. LCD TV
Green power light blinks every 3 seconds with the word Xerox on the screen, with just a black screen. Could this be a bad Switching Power supply cord?
open it up... whats the worst that could happen... see if the caps are fine... if they are bloated exchange them... if you need help doing so hit me up at abelino24(at)sbcglobal(.)net... I've repaired like three of these in the past few months.. its always the capacitors. they either get really hot and bloat or don't function if it gets too cold... so the solution if to get the right caps at 470uf / 25v and 220uf / 25v... hopes this helps...
Nov 18, 2006 | Xerox XG-71D 17" Flat Panel LCD Monitor
Sony VAIO VGN-FS660 Notebook Logo
26 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
