Question about Singer Sewing Machines
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
Problem with Singer Sewing Machines I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the plate and put the bobbin case and the bobbin back in it's place and tried to continue on sewing but sewing was not going right, I noticed that the bobbin case had some damage. I ordered two new Bobbin cases and still the problem wasn't solved.I did all the troubleshooting I could including some timming, cleaning and changing the needle. I gave up, I know I am missing something. The needle thread doesn't engage the bobbin thread and of corse there will no stiches. Thank you for your time
  • Singer Master
  • 1,564 Answers
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Posted on Nov 03, 2012
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
kent581
  • 87 Answers
SOURCE: bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Posted on Mar 18, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 68 Answers
SOURCE: I have a Singer Confidence 7469. It has only been
The bobbin case is not supposed to move. It should only have a little bit of wiggle room so there is enough clearence for the thread.
Posted on Feb 25, 2010
I have a singer 7468. THE BOBB IN CASE KEEPS POPPING OUT. CAN THIS BE FIX?
the sewing machine may need a new bobbin case,, but I would
suggest take the sewing machine to a repair shop to see if there
is something wrong with the hook & hook race,,that may be why
the bobbin case is coming out.
Oct 06, 2012 | Singer 7468 Mechanical Sewing Machine
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
I purchased an older Singer Stylist zigzag model 457 sewing machine at a garage sale. It doesn't have the owners manual and the bottom thread gets all knotted up. It also is hard to feed the material...
I can definitely help you with the owners manual. Go to http://parts.singerco.com/IPinstManuals/457A_105_125_135_143A.pdf and you can download it direct from singer, no viruses, nothing. Just save it in Adobe format.
The bobbin thread problem is called a birds' nest and can be from a number of problems. First thing to do is to change your needle, especially if it was the one you bought the machine with. It may look perfectly straight to the naked eye. But it only needs to be a little bent to cause a problem. If this doesn't clear the problem up, make sure you're using a new bobbin, freshly wound. If the bobbin isn't wound properly or is an old bobbin that's slightly bent or not quite round, it'll cause problems, too. Finally, the machine may need a new bobbin casing. Do a google search for Singer sewing machine parts and search for a bobbin casing for a model 457. You'll remove the plate from the top of the machine CAREFULLY (the screws are small, so be careful not to lose them!). Take pictures if you need to with your cell phone so you can see what to do when you need to put the new casing in. Bobbin casings are usually $25-30. This is the last thing, and I would only do this if you see that thread is catching on something in the bobbin area when you're moving the wheel by hand.
I've tried to be clear on the last bit, but I realize it can be a little awkward. If you need any other help with that, please leave me a comment back. It goes straight to my email, so I'll see it quick and will get back to you right away. The manual doesn't help a lot with your bobbin problem, so I'll do whatever I can to help you through it and get you sewing. Good for you for finding a great garage sale find!
Jun 08, 2011 | Singer Sewing Machines
Bobbin problems
Definitely needs retiming, I can attach instructions if you email me. drivewithken@blueyonder.co.uk
Jun 26, 2010 | Singer 2639
The bobbin case keeps sliding and popping out in the middle of sewing something. I'm having to unscrew the bobbin cover plate and put it back in on an average of four times each time I sew.
This is a real bummer! check to be sure you have inserted the bobbin case fully and correctly. Make sure there is no lint hiding behind the bobbin case.
May 31, 2010 | Singer 2639
My Singer 2639 Bobbin case pops up out of position after few stitches and needle hits case, Singer says it needs retiming and take it to repair. I cannot continue paying repair as this happens too often.
Hi, I used to have the same problem. I pulled the whole bobin casing out, cleaned it oiled it. When I put it back in, I made sure the actual bobin was turing the right direction so the cotton didnt snag and pull casing up.
If you havent already tried this give it a go.Its amazing how much gunk gets in there.
Sep 03, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
188 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
