Question about Maytag Performa PAV2200
Loud and noisy when the wash cycle starts.
Would also like to know how to remove the fabric softner dispenser.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Slide the unit out from the wall and open the small access panel on the back, bottom left side. 98% of the noise problems from this model is do to the bad design on the drain pump which has since been redesigned and will need to be replaced. Here is the new pump.
This washer pump has been redesigned by the manufacture. The mounting plate is no longer required. It now mounts directly to the base of the washer.
Posted on Nov 03, 2012
Buffalo12980
  • 625 Answers
SOURCE: Fabric Softner won't dispense
fabric softener goes into the dispenser. it may be a full blown solenoid valve -or- a flapper type of solenoid valve. operation of the solenoid operates a flapper to let the softener out. go to an appliance repair site to find the solenoid - appliance parts dot com or repair clinic dot com.
Posted on Sep 05, 2007
ngfam1
  • 639 Answers
SOURCE: Washer leaves fabric softner stain on white clothes
Dispenser wholes are probably clogged and all the softener is not dumping when it is supposed to!. Top loaders usually have a little cup like place to add the softener in the top of the agitator!
Those the Manuel tells you to rinse with water occasionally!
If you can't figure it out, call service and get it done and over!
You will feel better!!!
These guys are good
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Posted on Aug 24, 2008
WRMtech
  • 70 Answers
SOURCE: FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Posted on Feb 19, 2009
  • 784 Answers
SOURCE: Maytag MTW5620T2 the fabric softner despenser
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Posted on Jul 03, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Posted on Apr 20, 2010
Whirlpool washer wtw6800 fabric softener dispenser drains out before cycle
You can remove and wash the fabric softner dispenser drawer . It can also be adjusted on top of the dispenser
Oct 04, 2017 | Whirlpool Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Maytag neptune tl fav6800aww wont dispense fabric softner
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dispenser drawer and tub
softner dispenser has pushed down into the dasher. How to take off top of dasher to replace the small softner dispenser cup that was pushed down.
Apr 13, 2009 | Washing Machines
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Sep 04, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
218 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
