How do I install a Top Performance table top replacement mat on the grooming table?
Do I use glue? What kind of glue? Should I remove the original mat first?
  • 4,349 Answers
I would use contact cement. It is applied to both surfaces and is allowed to dry to touch. Then when you next touch the surfaces, they will be permanently bonded. You can find water based cement, MUCH easier to work with.
Consider using lots of dowel rods to keep the materials separated as you assemble.
Normally you would remove the original mat, sometimes you can bond to it.
Posted on Nov 03, 2012
  • mariettae
    mariettae Nov 04, 2012
    Thanks Mike -- appreciate your help. I was thinking along the same lines...just saw a video on how to apply laminate to furniture and they uaes the same technique with the dowel rods. Mt doggie thanks you too!
Need to replace bulb coast hp7 flashlight. How to access bulb?
Unscrew the top. Unfortunately, very tight looks like Coast used some kind of glue. Ridiculous setup by them.
Sep 26, 2013 | Coast HP7 High Performance Focusing 251...
How do I get a glob of dried super glue off the top of a wood dresser?
did you try putting ice on top of it freeze it and tap it with butt of screwdriver it should shatter and take a towel and dry table
Mar 03, 2013 | 3M SCOTCH SUPER GLUE GEL - AD119
I broke off one of the tabs that hold the table saw throat insert in place. It's cast iron and I don't think it would weld. Tried glueing it and it came off again and now I've lost tab. Wi
You could make a tab to replace the original that you can hold in place with a countersunk screw through the top of the table. You are probably going to have to flip the saw over so that you can grind a flat spot where you can mount the new tab. You might even have to cut a gap in one of the cast webs. If you don't want to cut a web, your replacement tab is going to be a bit trickier to make.
Good luck! (I am trying to imagine how on earth the tab broke!) And by the way, it is possible to weld cast iron but I think it would be a mistake to try it because it would almost certainly warp your table.
Oct 21, 2012 | Jet Used JTAS-10XL 10" Table Saw 50" Rip
What should I do to prevent matting?
In order to prevent matting you should brush your dog at home before you bring him in for a grooming appointment.
Aug 15, 2012 | Pets - Others
What is a standard grooming session?
A standard grooming session usually includes ear hair removal, ear and eye cleansing, nail clipping, de-matting, de-knotting, dead hair removal, clipping of unwanted hair from, washing, conditioning, rinsing, and high velocity drying. It is better to check what's included before you bring your pet in.
My dogs hair is extremely matted. How can I best remove all the matting?
You will need both a slicker brush and a bristle brush. Begin by teasing out the mats with your slicker brush and then use the bristle brush to go over the coat. If the matting is too hard to remove using the brush, you may need to trim some of the hair.
Do I need to bathe my cat?
Cats are able to bathe themselves, generally speaking, with their tongues and teeth. Nevertheless, there will be times when you will need to bathe your cat - if he/she gets into something really dirty/sticky would be an example of one of these times.
How can I make a really cheap sofa table?
Cut ListCut List: A) 4 - 1x3 @ 29 1/4" (Fronts and Backs of the Legs) B) 4 - 1x2 @ 29 1/4" (Sides of the Legs) C) 2 - 1x3 @ 10" (Side Support) D) 1 - 1x2 @ 37" (Stretcher) E) 2 - 1x3 @ 37" (Side Trim for the stretcher) F) 2 - 1x4 @ 10" (Side Apron) G) 2 - 1x4 @ 37" (Front and Back Apron) H) 1 - 1x12 @ 48" (Base for the top) I) 2 - 1x4 @ 11 1/2" J) 1 - 1x12 @ 41"
Step 1
Download Original]'>untitled-3%20(15).jpgConstruct your legs by nailing through the 1x3 legs into the edge of the 1x2 legs with 2" nails and glue. The legs will be positioned with the 1x3s to the front, 1x2s to the side, as shown in the diagram.
Step 2
Download Original]'>untitled-4%20(14).jpgStart by marking each of the legs 5" from the bottom of the board. This will be the bottom of the side support, C. Nail C to the legs, using 1 1/4" nails and glue, from the inside.
Step 3
Download Original]'>untitled-5%20(13).jpgNow add the stretcher, D, centering D on the support, C, but keeping the top edges flush. D will lay flat, with the wide side up. This is demonstrated above. Use glue and 2" nails, nailing through the support, C, into the end of D.
Step 4
Download Original]'>untitled-6%20(9).jpgAdd the side trim pieces, E. First, nail through the supports C into E, using 2" nails. Then nail down the length of the stretcher, taking care to keep the top edge of the stretcher (D) perfectly flush with the top edge of the stretcher support (E). Use glue and 2" nails.
Step 5
Download Original]'>untitled-7%20(8).jpgNow use the 1 1/4" nails to nail through the back of the side apron pieces, F, into the legs. Use glue. Keep top edges perfectly flush.
Step 6
Download Original]'>untitled-8%20(7).jpgDo the same for the front and back apron pieces, G, as shown above. Nail through G into the legs using 1 1/4" nails and glue. Keep top edges flush. Take a minute to check for square
Step 7
Download Original]'>untitled-9%20(7).jpgNow add the base top, piece H. Keep the front and back edges flush with the legs, but let the sides overhang 4" on either side. Nail into the legs and the apron using 2" nails and glue.
Step 8
Download Original]'>untitled-10%20(6).jpgUse glue and 1 1/4" nails to attach the breadboard ends to the base top. Keep all outside edges flush.
Step 9
Download Original]'>untitled-11%20(5).jpg I recommend not cutting the final piece, J, unitl you have taken an exact measurement. Add the final piece, using glue and 1 1/4" nails.
Finishing Instructions
May 29, 2012 | Furniture
HOW TO REPLACE 2003 YUKON GMC SPARK PLUGS
Remove the wire from the top of the spark plug by twisting and pulling on the boot part. Then you will need a 14 milimeter plug scocket wrench, turn the wrench counter-clockwise to remove. You install them by doing the steps in reverse. A note of caution: the tightening force is 15 foot pounds of torque whitch isn't a lot of force.
The original spark pulgs are good for at least 100,000 miles unless it's had a problem to cause them to fail. Also installing a different type plug then original equipment has lead to poor performance at times.
Feb 13, 2011 | 2003 GMC Yukon
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
