Question about Refrigerators
How to install door on JENN_AIR mod.JRT236 ******
I HAVE THE PARTS TO HANG THE DOORS BUT DO NOT KNOW WHAT GOES WHERE, A DIAGRAM WOULD HELP. TANKS PAT HOLMES
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
This is all I can come up with. It may help you some.
Posted on Nov 03, 2012
catriver
  • 878 Answers
SOURCE: Door closer problem ....door pops open
PJ, as long as you don't have any shelves preventing the door from closing, it probably is the cam that sits on the bottom of the refrigerator door. In order to change it out you will have to remove the entire refer side door. Lay it down and replace the cams on the bottom. I don't have a model number here so I can't give you a part number. You will have to remove the top hinge and the door will lift up and off. Then replace the cams, you will be able to see how they go on when you take the door off. Before anything check to see that the door is aligned ok. You have some adjustmet on the top hinge. You also have some adjustment by raising and lowering the front wheels. You can also try lubing the cam that is on there now....Catriver.
Posted on Oct 10, 2007
the dr
  • 447 Answers
SOURCE: jenn air french door refrigerator broken by repair company
Ill be glad to shed some light on this for and stand behind this as I too am a Factory authorized dealer. These units did come with faulty compressors failing about 80% of the time. What happens is the compressors get worn and stop starting properly. You can make them work temporarily by installing a 3n1 (basically makes the compressor have more starting torque). However they eventually get so worn that even a 3n1 cant start it. Ive never read any bulletins from any major company (Frigidaire used this same compressor) saying a 3n1 voids warranty. It certainly didnt damage the compressor it was already damaged when the tech installed the 3n1. Also these compressors are failing at such a high rate its not even questionable that the 3n1 damaged anything. Honestly it really sounds to me like the tech is nit-picking not wanting to do the labor intensive job of changing the compressor. He may not even be able to. Also the new compressor should be a 8201555 (I just did one this afternoon ---thats how common this is) and its a much more reliable Embraco compressor. Once its installed you should have no more compressor issues for many years. Feel free to have anyone who questions my solution to call anytime 850-510-9563 (Joey Shearer, Precision Appliance, Tallahassee, FL)
Posted on Jan 15, 2008
aborcass
  • 2651 Answers
SOURCE: Jenn-Air "replace filter" light
each dispensor is a little different, but youll need to hold down a button(perhaps even a combonation of 2) for3 seconds to "reset " the filter indicator.
Posted on Mar 19, 2008
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Posted on Jun 11, 2008
How do i fix my jenn-air refrigerator JSD2488DEB .The damper door and spring fell off while removing a part.I have no idea where the spring is placed?
Parts for Jenn Air JSD2488DEB Shelves Accessories Parts
This might help. However you could try putting the damper door in without the spring and moving it through its open and closing to see what is near the door the spring could hook to. Look for small holes or tabs.
Dec 31, 2014 | Jenn-Air Refrigerators
Top door not aligned with bottom
The parts diagram link that I am sending shows the hinges. You can adjust them. http://www.appliancepartspros.com/left-refrigerator-door-parts-for-jenn-air-jfc2089htb.html Loosen the screws and shut the door and then tighten them
Apr 07, 2014 | Jenn-Air JFC2089HTB French Door...
I have a Jenn air mod JS48PPDUDB00. It's makes ice fine but the ice dispenser door will not open far enough to allow ice to fall out. What should I do? Replace door motor and ice door?
There is an ice door solenoid that pulls that open and the linkage may be binding. Check www.searspartsdirect.com and look at the diagram and parts list. Look for the ice door kit.
Oct 29, 2013 | Refrigerators
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Broken Handle on Jenn-Air Model M406 Under Cabninet Microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Nov 24, 2008 | Microwave Ovens
Jenn-Air micro-wave oven serial number #JMV8208AAS
This is the door latch, and replacing it is not a bad job for a do-it-yourselfer, in case you or someone you know may want to do it.
You have to separate the door panels (as shown in the attached photo) and then you'll see how you can replace the broken door latch. (Don't lose the spring!)
Or you can watch a YouTube video (not a video I made) that demonstrates how it's opened.
If you don't want to do it yourself, you can find your nearest Jenn-Air / Maytag-authorized servicer here.
They generally charge about $75 to visit the home, $75-90 to do the repair work, and the part may run about $15 or so. If nothing else, you can save about $75 by taking it to the shop yourself.
I'd suggest a helper for that task, and you can download installation instructions here.
Nov 05, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Replacing outer glass and stainless steel door on my jenn-air microwave oven
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 30, 2008 | Jenn-Air JMC8130DD Microwave Oven
Jenn-Air Expressions Mod. W30400BC
no adjustments hinges are mounted inside door panel right?check to make sure theres no damage to inner door panel
Mar 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
