Question about GE Washing Machines
GE Profile WPRE6150K2WT - washer pumping water but will not spin
Washer pumping water but will not spin; replaced board asm mount but still not spinning.
    Top Expert:
  • GE Master
  • 9,472 Answers
Unplug the electric power cord. Disconnect the hoses and pull out the drain hose. Move the washer to a convenient location where you can work on the front and the back of it
No washer will spin when the lid is up. If the lid is down and it still wont spin, the first thing to check is the lid switch. If it's bad, the washer will think the lid is up all the time. You'll need to remove the front panel of the washer to see it.
Find the clips that hold the front of the washer on. They are on the front, about 3 inches from the sides. If you shine a light into the crack, you will be able to see these clips.
Insert a putty knife, pressing on the clips to release them. Then remove the front panel. Find the lid switch. Mine was on the right side. Make a note of the color of the wires that go to the lid switch.
Remove the back panel at the top of the washer where the timer and other controls are located. I needed a nut driver and a torx screwdriver.
Inside the back of the head unit, find the wires that come from the lid switch. Disconnect the white plug the wires go into.
Attach a volt meter to the end of the plug that comes from the lid switch. Set the meter to measure resistance or continuity. This means when the wires of the volt meter are touched together it beeps or shows a value of zero. Open and close the lid. If the readout on the meter doesn't change at all, then the lid switch is faulty. Replace it and the washer will now spin. If the lid switch is OK, go on to the next step.
Washers pump out all the water first, and then start spinning. If the water level switch is bad, the washer will think there is still water in the tubGE Profile WPRE6150K2WT - washer pumping water but - icon1.png and refuse to spin. From the front of the washer, locate the clear plastic hose on the left side. This goes to the water level switch.
Disconnect the hose by pulling upwards. Cleanicon1.png any junk out of the hose. On my washer, this clear plastic tube had some lint in it. By sucking on the tube at the front of the washer, I was able to remove it and the washer then worked perfectly. If this doesn't work for you, continue to the next step.
From the back of the washer, locate the water level switch on the right side. Disconnect the plug and attach your volt meter to the wires that come from the switch. Blow into the end of the hose you disconnected at the front of the washer and see if the meter changes. You should hear a clicking sound as you repeatedly blow into the tube. If the meter doesn't change at all, then the water level switch is bad. Replace it and you washer should spin correctly. If you are certain the lid and water level switches are OK, and the water level tube is not clogged. Then the problem is either the clutch or the motor
Posted on Nov 03, 2012
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
mgprice
  • 744 Answers
SOURCE: GE Profile wont spin,why?
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wiring to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you replace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Thanks for using Fix-ya. A high rating would be appreciated for your free question :)
Posted on Jul 26, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
richroth
  • 9472 Answers
SOURCE: 2008 GE PROFILE WASHER. THE WASHER WILL RUN
You need to replace the "lid switch". Here is a link to the part you need. Here is a link to a video that may help you.
Posted on Dec 02, 2010
My Ge Eterna washer will not drain the water but will spin on spin cycle
You got no clear question here. Does the spin cycle pumping out water or not. If it is spinning but water was not pumping out so the issue is from the pump. It is either blogged or out of order.
Oct 15, 2013 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer how do you bypass lid safety switch? Unit pumps but won't spin.
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Dec 19, 2010 | GE Profile WPRE6100G Top Load Washer
The "floating drum makes out of round knocking noise in spin cycl
On the bottom of the washer tub is a "balance block?" that the bolt has loosened on. Have GE come repair it. We just had it happen to us as well. If you don't get it repaired it will cause more damage to the washer and then it won't be covered under the warrenty.
Jun 01, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
GE washer Wbb4500GWW Won't spin
This is a defective board assembly. replace the entire board assembly if possible. it has become unstable and unable to initiate the proper wash sequence.
Jun 19, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Water leaks under washer on floor - olderGE profile
I see Eric C was correct, that you did not post your correct model number. You did say older GE, and from your description it sounds like you need to replace the WH23X42 water pump (about $50). It is one 1/4 inch clamp on the bottom holding on the flexible drive, three 5/16 hex head screws mounting the pump body to machine, and four squeeze style spring clamps holding the hoses. (be ready to catch the water when you remove hoses)
Feb 17, 2009 | GE Profile WPRE6100G Top Load Washer
Ge Profile washer
pump might be pluged or something caught under the basket in the washer.
Dec 10, 2007 | GE WPGT9360EPL Top Load Washer
Washing Machines Logo
328 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
