Question about Relisys TL 766 Monitor
The Menu always shows
Well the like, dipslay menu is always showing i have managed to move it and make its kind of translucent so i can deal with stuff but it still really bugs me.. i have tried my monitor with another computer and its still there its driving me crazy! please help! thanks in advance
    Problem Solver:
  • 9 Answers
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
SOURCE:
Desktop background doesn't show
I get this too. (Love using the solid blue background)
1. Check if there are any other users logged in on the Mac.
2. Log off all the users including yourself
3. Log in only on your user account and change the background
If that doesn't work, restart first and repeat.
If even that doesn't work, change to another solid background first and then change it back to the picture.
Dec 18, 2013 | Apple Mac Mini Desktop
How can I do to show on the screen the activation of the caps lock key?
You can "hide" or "show" it from the notification area via:
Start > Settings > TaskBar & Start Menu > place a check next to "Hide inactive Icons", then click Customize, Located the items and you will see a drop down menu appear. Select "always hide" or "always show" and click OK > OK.
Mar 30, 2013 | Computers & Internet
Sir i have micromax q50 ezpad, i am facing problem to open massege menu, shows alway loadind, and internet menu shows always internet service not ready, kindy help me
actully sir i have micromax Q5 and i m facing the problems like the massage menu is not opening , defult web browser is also not opening ...
Aug 07, 2011 | Cell Phones
Hi Sir, I have a Micromax Q5 handset. Whenever i try to send/forward a sms its shows "NOT ENOUGH MEMORY".. Kindly help me.. Saurav agarwal 91- 9891920785
Hi, please go to main menu, then multi media, then file manager, open file manager, select phone, then either delete certain file or move it to your memory card or format it, problem solved. I hope this helps. I got the same kind of problem and figured it out.
Micromax Q5
Apr 10, 2011 | Cell Phones
Where do I find my book marks etc.. I see nothing at top of page ty
If you want to create the bookmark bar
  1. Click on the wrench icon in the top right
  2. Select Tools
  3. Select Always show bookmarks bar
Alternatively you can use ctrl+shift+B to turn the bar on and off
Mar 03, 2011 | Google Chrome
HOW TO GET THE PICTURE TO SHOW RIGHT TO LEFT
The projector may be set in the 'rear' facing mode; to show through a translucent screen. You can toggle this 'reverse image' feature in the 'system menu'. Here's the link for your projector's manual:
http://www.infocus.com/~/media/library/reference_guide/English/InFocus_LP70%20_reference%20guide_en%20%20pdf.ashx
On page 34 of the pdf document (manual page 18), the manual describes how to access the menus. On page 40 of the pdf (manual's page 24), the System Menu is described. The first feature in the system menu is the 'rear' function to reverse your projector's image, so it shows backwards or not.
Hope this helps. thanks,
jake
Nov 13, 2009 | Office Equipment & Supplies
My calendar program is missing..
IN MENU--> SELECT BLACKBERRY LOGO BUTTON--> SELECT SHOW ALL.
1.To hide a Home screen icon, complete the following steps: Select an icon on the Home screen of the BlackBerry smartphone. Press the Menu key.
Click Hide Icon.
2.To show a hidden icon on the Home screen, complete the following steps:
Press the Menu key. Click Show All.
3.After the Show All option has been selected, to show a hidden icon, complete the following steps:
Select the transparent icon on the Home screen that you want to make visible.
Press the Menu key.Cancel the Hide Icon selection.
4.If not able to find Install Blackberry desktop Manager ...Take Backup.. reinstall the application from application loader in Blackberry Desktop Manager
Aug 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Toshiba tube tv display doesnt show
when you unplugged it,it reset the clock.you need to set the clock.
on the remote play with the input,menu and display buttons until settings come up.one the date and time is set,probably ok.the best thing is to see if your friend has the manual.there are literally hundreds of different toshiba t.v. alone
May 22, 2009 | Toshiba Televison & Video
Light red translucent stripe at top of screen
On your Remote
>menu
>parental controls,favs & setup
>system setup
>display
>centering
You can use this screen to move your picture up a bit and get rid of the line. If it doesnt work the first time, move it a little more. Good Luck!
Aug 03, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Relisys TL 766 Monitor Logo
100 people viewed this question
Top Relisys Computers & Internet Experts
Marvin
Marvin
Paul
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
