Question about Whirlpool Washing Machines
MANUAL DE SERVICIO LAVADORA WHIRPOOL CABRIO
PROBLEMAS CON ERROR F1
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: CADA VEZ QUE EMPIEZA
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$%%
Posted on Sep 21, 2010
bbl242003
  • 1637 Answers
SOURCE: hola tengo una lavadora whirpool cabrio traida de
Your input panel needs to be serviced. Please try to change the AC outlet location first before attempting the service yourself. If your still experiencing problems, then remove the front panel to locate the the soldered joints behind the power button. There is a relay which may be worn and can be changed by you. You may find the area covered in rust and oxidized. If this is the case, then we have found the root cause behind your problem and will need to change out the bad part. Please reply with any question
Posted on Jan 25, 2011
SOURCE: mi lavadora whirlpool cabrio al
mi lavadora se bloqueo y solo dice ld
Posted on May 17, 2011
COMO REPARO UN MICROONDA PANASONIC CON ERROR H98
H97, H98 o H99 significa que hay un problema con el inversor, magnetr?n, o el circuito de programaci?n digital.
Debido a las tensiones letales utilizados y producidos, no se recomienda que una persona sin experiencia de trabajo en estos. Yo recomendar?a que se ponga en contacto m?s cercano de servicio autorizado de Panasonic.
Soluci?n de problemas de circuito inversor (U) y Magnetron
Este horno est? programado con un sistema de auto diagn?stico c?digo de error que le ayudar? a solucionar problemas, H97, H98 y H99 son el fracaso y el inversor siempre magnetr?n ?reas problema en el circuito. Esta secci?n explica los c?digos de falla de H97, H98 y H99. H97, H98 y H99 aparece en la ventana de visualizaci?n poco tiempo despu?s de clave de arranque es presionado y no hay oscilaci?n microondas.
Forma alternativa para solucionar el horno con aire acondicionado Ampere medidor utilizado.
H97, H98 y H99 aparece en la ventana de visualizaci?n un corto tiempo cambiar clave de inicio es presionada y no oscilaci?n de microondas con amper?metro de CA utiliza para solucionar problemas.
Compruebe filamento del magnetr?n abiertos o en cortocircuito a la carcasa antes de proceder a determinar un buen magnetr?n.
Espero que esta informacion le sea de ayuda (recuerde valorar esta respuestas gratuita).
Sep 20, 2011 | Microwave Ovens
Es una whirpool cabrio 6600SW1 el problema es que comienza a golpear el tanque de un lado al otro en el ciclo de centrifugado necesito los repuestos soy del ecuador podrian ayudarme donde consigo y...
tengo un problema con mi whirpool cabrio 6600sw1 selecciono en ciclo del lavado y empiesa a llenar cuando yega a su nivel de agua la tira y la numeracion se baja a 5 ¿Qué puedo aser?
Jun 28, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hola midvd no lee los discos el laser si funciona pero en la pantalla me dice que no hay disco a donde lo puedo llevar para que lo reparen?
Hola
Su unidad de lector l?ser tiene problemas. Sustituci?n de que es un trabajo especializado, y debe ser realizado por alg?n t?cnico de servicio con experiencia. No ha dado ning?n n?mero de modelo de la marca de su dispositivo. De todos modos, es repararlo por su centro de servicio autorizado, por cualquier technican de servicio con experiencia. Aceptar.
Jun 14, 2011 | Durabrand PDV-709
Me hace falta el numero puk
Bienvenido a Fixya,
c?digo PUK se puede dar s?lo por su proveedor de servicios que es espec?fico para cada n?mero de tel?fono m?vil. P?ngase en contacto con su departamento de atenci?n al cliente SIM a trav?s del tel?fono. Su libre de costo para obtener el PIN o PUK no. Si no puedo ponerte en contacto a trav?s de su tel?fono conseguir otro tel?fono y en contacto con ellos. Ir a la salida de servicio m?s cercano de su proveedor de servicio que tambi?n le puede ayudar. No hay otra que ir el procedimiento anterior s?lo su proveedor de servicios que cangive
Espero que esta informaci?n le ayudar? a resolver su problema con el tel?fono
Gracias por usar Fixya.
Feb 23, 2011 | Samsung SGH-D500 Cellular Phone
Tengo un problema con la impresora kyocera fs-4000dn, que me sale el mensaje llamar servicio 7410:0052827, me gustaria saber a que se deve el problema. saludos...
tengo un Problema con mi empresora Kyocera FS-4000DN Laser Printe. me aparece comprobar caja de toner y no me deja imprimir les ruego q me colaboren muchas gracias por los servicios
Sep 23, 2010 | Kyocera FS-4000DN Laser Printer
What is an F1 error message?
El codigo F1 para las Whirlpool Cabrio lo define la se?al de presion fuera de rango, para esto, primero hay que verificar el estado del tubing plastico ? manguerita que va de la tina hasta el sensor que esta en la tarjeta principal, que no este rota y/o doblada, luego realizar el test # 6, nivel de agua y calibraci?n del sensor de presion. Para esto hay que estar seguro de que la tina este sin agua, al igual que el tubing, luego entrar en test modo 2 y seguir los pasos.
Jul 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Necesito ayuda urgente si ustedes son tan amables de ayudarme se los voy agredecer yo necesito el service manual porque compre 10 dictaphone 2750 desktop tengo problema con tres de ellos porque el motor se...
Hola Soy Tecnico en servicio de SONY y Dictaphone Y estas en lo correcto el modelo de Dictaphone 2750 Stadard cassette uno de sus problemas es que si la unidad queda con el cassette dentro y sin seleccionar auto encendido el motor queda funcionando asi que se muere mas rapido la verdad es que necesitas remplazar el motor y el motor solo tine dos cables asi que no es mayor problema el remplazarlo te puedo dar un correo para que solicites el motor normalmente esta compania no vende partes solo da el servicio de reparacion de las maquinas pero puedes decirles que Javier te recomendo para comprar estos motores que nececitas, despues de remplazarlo tus maquinas quedaran bien otraves email to service@tvps.com
Nov 30, 2009 | Dictaphone 2750 Desktop Cassette...
Quisiera saber si hay que cambiar tarjeta
Checkas aqui... http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WTW6600&siteCd=WHRCOM porque hay informacion en espanol en los instruciones por tu lavadora.. los instruciones dice: Oprima Pausa/Anulación (PAUSE CANCEL) una vez para despejar el código. Presione Inicio (START). Si el código aparece nuevamente, llame al servicio técnico.
Jun 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
