Question about Samsung WF203ANW Front Load Washer
Samsung j1253 wont empty cleaned every hose filter relaced pump and a new triac on display board still wont empty what to do next
My front loader samsung j1253 will not empty we have cleaned every hose and filter brought new pump and replaced a triac on display unit and still wont empty why and what else should we do
    Sergeant:
  • 264 Answers
It might have blown a track on the programmer if so then you will need a new bold ok
Posted on Nov 03, 2012
  • 1073 Answers
SOURCE: Samsung Front Load VRT - nd error
where did you buy it from, call the store and tell them if they cannot get you the proper service to replace it
Posted on Apr 25, 2008
nanbuenbrazo
  • 553 Answers
SOURCE: how to install drainage hose on Samsung J845 front
See where the opening to access the mechinacl compartment, other washing machine is at the back and others are at the bottom
If at the bach just turn it backward towards you then unscrew the cover, from there you will the connection from drainage hose.
you can replace it from there, but you should have some sealant with you to avoid any leackage
if it is located at trhe bottom, then turn it up side down then do the unscrewing and removing the cover, then change it
Posted on Nov 04, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: getting error 5e WF7708 samsung front loader. Have
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Posted on Jan 06, 2010
Testimonial: "i was draining the water out only coming out in dribbles so i think you hit the nail on the head....ty ty will give it a go..."
SOURCE: front loader wont spin
-my samsung front loader wont spin
Posted on Nov 14, 2010
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Posted on Jan 22, 2011
ERROR CODE "ND" IS DISPLAYED ON SAMSUNG WASHER WF316BAC/XAA SO I REPLACED PUMP BUT STILL DOES NOT DRAIN WATER - WHAT TO TRY NEXT?
if the machine cleans ok its probably not the pump , but is either the drain valve actuator or "seen it a million times" the drain hose is clogged up with YUK !! when they get really bad with who knows what blocking them !! I opt for the new 20 dollar hose rather than sticking something down there to push clogg out !!
May 26, 2017 | Samsung Washing Machines
Is there a filter on Samsung washer model WF337AAL/XAA
should b were the pump connects to or up inside the hose from mech to pump
Feb 19, 2015 | Samsung Washing Machines
SAMSUNG J1253 ERROR CODE 4E
Did you leave out the complete model number?, If you haven't yet check your water supply, If you changed to or have the auto stop flood hoses some washers cause them to activate.
The wires may be disconnected on the water valve(s) or a valve went bad or the main board went bad, You can use a meter to check that there is voltage going to the valve(s) when you start a fill cycle, Also some washers use a flow meter that checks water flow.
May 03, 2017 | Samsung Washing Machines
Samsung j1253 error 4e ?
Samsung's '4E' stands for 'water supply error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 06, 2011 | Washing Machines
How do you remove the filter on the back of a VRT Steam Samsung washer?
Actually there should be a little door you can access at the bottom front to clean out your pump filter, I'm including my washers pictures. 1) You first open the little door at the bottom. You do not need any tools, just something to drain the water in to. 2) Unscrew the hose closure, put your hose down into the drain bucket. Drain all the water out, you may have to empty the bucket so you can get the hose lower next time. 3) Next unscrew the filter itself. Get anything out inside the hole, in my case it was a toothpick, I take a paper towel and dry out any grit or hair. 4) Put your hose closure back on, it is held in a clip, Then screw the filter back in. That's it. I would also recommend cleaning out the drawers that hold soap, bleach and fabric softener. Also clean around the rubber ring, it will help your washer last longer. lanijo58_3.jpglanijo58_2.jpglanijo58_1.jpglanijo58_0.jpg Hope this helps you
Jun 02, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
My washer machine keeps displaying OE. We have checked all the hoses, and everything seems fine. Will not empty water or finish cycle
Error Message : the OE is (outlet error).
1) If OE error occurs, clean & empty the filter.
2) If this doesn't solve the problem, and it won't drain, then provided that you can hear the pump spinning (the normal whirring the machine makes that should be accompanied by the water going down the drain) then the hose pipe leading to the pump is probably blocked.
I'm sure a lot of dodgy service people might just charge you for a new pump & labor, but if you can hear the pump spinning then you just need to remove the blockage.
Aug 12, 2010 | LG WM-1832C Front Load Washer
Hotpoint aquarius 1200 wont empty and I cannot find the filter to try and clean it out
HI. the filter is mounted on the drain pump housing. You will need to disassemble the unit to access the filter. Here are some other areas i would check, also.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious issue within the actual control sector(Timer module or control board). It should be replaced i this case.
Oct 25, 2009 | Hotpoint Washing Machines
Display reads "pump blocked"
TURN OFF MACHINE AND UNPLUG THEN DO THE FOLLOWING:
Open the pump filter cover:
23294f2.png Remove and uncap drainage hose to empty detergent and then replace the cap.
Unscrew the filter and clean it, inspect the filter cavity inside the machine for matter that might be blocking it. Check the waste hose that leads out of the machine to see if there is a restriction somewere.
Oct 15, 2009 | Siemens WM14S794GB Front Load Washer
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Samsung WF203ANW Front Load Washer Logo
218 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
