Question about Dryers
Dryer check filter light comes on
Check filter light comes on yet the filter and vent line is clear.
    Sergeant:
  • 264 Answers
Take out and make sure you have puched it as far as it will go by takeing it out and putting it back should **** the sencer switch with is at the back of the filter not on the filter its self its in the dryer at the back where the filter puchs at it keep takeing it in and out ok if that dont work try cleaning at the back of the filter in the dryer where the filter go's ok should do it it only takes a little bit of fluff to stop it from working ok
Posted on Nov 03, 2012
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
SOURCE: dryer shuts off on own lights blink
Turn off breaker wait an hour turn back on.
Posted on Apr 04, 2008
  • 91 Answers
SOURCE: dryer shuts off after 5 or 10 minutes
repl/ thermsitor if avaiable if not repl/ hi limit thermostat on top of ignitor
Posted on Jan 04, 2009
  • 70 Answers
SOURCE: no heat, dryer exhaust vent cleaned, still no heat, gas line is on
I think you have a gas dryer, and a bad ignitor.
Posted on Apr 23, 2009
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
Samsung dryer
Check to make sure the exhaust vent is clear of lint and any other obstruction.
Aug 15, 2014 | Dryers
Mdg7600 gas dryer replaced coil- hot surface igniter lights then shuts off -bypassed cycling thermostat still no luck
if it lights then most likely you have a block somewhere with lint,pull out the lint filter and then remove the duct that the filter slides into and clean it out,with a shop vac set it up to blow and blow off the burner tube,the motor and the whole cabinet,put it back together,now go to the back,remove the vent line and start it,if it runs fine until you reinstall the vent line then you have a block in the line,i use a leaf blower,i remove the vent line,go outside,make sure the outside duct is clear,nothing blocking it like a cage or screen,go back inside,stick the leaf blower into the vent line and blow it out to the outside,this usually clears it.lint buildup is the most common problem with dryers.let me know what you find.if you already changed the gas coils and ignitor and the flame does light most likely bad air movement.
Oct 10, 2013 | Maytag Dryers
Lg dryer check filter light wont stop blinking and the dryer wont work
You may have a clogged vent line.
Which will cause the check filter light to go on sometimes.
If the air is not getting out the vent and is blocked the sensor thinks the filter is clogged.
And you will not get heat either.
Check that the flexible vent line behind the dryer is not kinked or crushed.
A simple way to check if the vent line leading out from the dryer to the out side of the house is clogged is to remove the vent line from the rear of the dryer.
If the dryer gets hot when the vent line is removed, then the clog is between there and the outside vent door.
sometimes the little door outside the house gets stuck closed due to lint build up.
Or anything can be in the vent going into wall too.
Oct 20, 2012 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
My check filter light is on, the buzzer wont work but it is still drying
Hi
The electronic display on an LG dryer includes a "Check Filter" warning light. The light is primarily for convenience and does not indicate a major malfunction.
You may have a clogged vent line which will cause the check filter light to go on sometimes. If the air is not getting out the vent and is blocked the sensor thinks the filter is clogged. And you will not get heat either. Check that the flexible vent line behind the dryer is not kinked or crushed. A simple way to check if the vent line leading out from the dryer to the outside of the house is clogged is to remove the vent line from the rear of the dryer. If the dryer gets hot when the vent line is removed, then the clog is between there and the outside vent door. sometimes the little door outside the house gets stuck closed due to lint build up. Or anything can be in the vent going into wall too.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 02, 2011 | LG DLE2516 Electric Dryer
When I turn on the dryer, the top gets VERY hot within about 2 minutes. When I look inside, you can see the heating element is red. I checked the vent and it is clear. I did notice that there was some...
if the lint is damp then the air isn't moving out the vent line,unplug the dryer, go outside and make sure the hood is clear, then go back inside and remove the vent line from the back of the dryer,if the vent line is long i use a leaf blower to blow out the line,just stick it into the vent line and blow it so all the lint will go outside,if you could have someone watch the outside and they can let you know when the line is clear,also the duct that the lint filter slides into should be cleaned out and you should vacuum out where the motor is,you have an open flame inside the dryer and the lint can and will catch fire if it's not cleaned out,i do this to my dryer once a year,the clothes dry on time,no fires and the parts in the dryer last longer from being cleaned and the dryer isn't overheating and damaging the motor and other parts from running to hot.let me know how you make out
Oct 29, 2010 | GE DVLR223 Dryers
Kenmore Dryer not working
when was the last time you cleaned out the dryer?there's a thermal fuse located on the top of the blower wheel housing that pops if the dryer overheats from a clogged vent line or for whatever reason the air isn't moving.unplug the dryer,if the filter is on top then the thermal fuse is in the back of dryer next to the duct that the lint filter slides into,if the filter is inside then the thermal fuse is in the front of dryer to the right of the duct that the filter slides into.unplug the dryer,with a meter read out the thermal fuse,whatever part you are reading out you have to remove at least one of the wires so you don't get a false reading.next if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to blow out the vent line,make sure the outside vent is clear before you blow out the line,any cages or screens remove them,next you need to clean out the duct that the lint filter slides into,if filter is on top don't forget to remove the two phillips screws in front of the filter on the top panel and vac out the inside of dryer where the motor is,you should do this once a year so you don't pop anymore parts,you won't have a fire and your clothes will dry on time and save electricity.let me know how you make out
Apr 20, 2010 | Kenmore 62602 Electric Dryer
The dryer is working but has no heat and not drying. The filter light is on all the time even though the filter is empty
check the vent line and port outside the house you can disconnect the vent line at the back of the dryer and see if the light goes out
Mar 20, 2010 | Dryers
Dryer wont heat and check filter light is on but filter in dryer is clean?
This could be caused by a venting restriction. These dryers have sensors built in to check airflow temp differences. Take the vent off the dryer and run it and see if it heats. If it does then you know the problem is with your venting. You will need to either clear the vent or replace it.
Hope this helps _MJ_
Feb 01, 2010 | LG DLG5932W Gas Dryer
Doesn't dry clothes. New Just installed 11/16. Took 2 hours to dry a load of towels. It is a gas dryer. WGW 9450
Check vent out is clear blowing air / check clean all filters, the fact thats its new should not be anything too serious..Good luck
Nov 17, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Check filter light remains on. Start button seems to not be working
If the filter is clean, a blockage or lint buildup in the vent line could cause this problem. Make sure the vent line is clear all the way to the outlet.
Aug 25, 2009 | LG WM3431 Front Load Washer / Dryer
Dryers Logo
251 people viewed this question
Top Dryers Experts
