Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Dubbing to dvd no longer works, no error code
I've had this unit for about a year now (guessing), replacing an Emerson brand (if I'd known they were made by the same company I'd have gotten something else). It's been working fine until last night in dubbing my VHS tapes to DVD. Last night, it started just giving me a big red NO symbol when I hit the direct dubbing button. I've tried two different tapes, reloaded the disc (checked to make sure it wasn't damaged), shut it off and let it cool down and it still gives me the same symbol. Any clues on what's going on?
Apparently the disc I was using had something wrong with it, but not until I was almost 4 hours into dubbing something over. Changed the disc and started over and it works fine now. I guess with all the problems I had with the Emerson unit, I figured this one was about to buy the farm as well. Sorry to bother anyone.
Posted on Jan 05, 2009
After dubbing from vhs to dvd, the dubbed dvd is placed into a PC but it comes up saying the dvd is blank..We used a dvd+R dvd. Any ideas?
First did you finalize the disc after dubbing? When the DVD/VCR recorder is in stop mode, press Menu and navigate to Disc Settings > Disc Finalize and select Finalize and press Enter. Select OK and then Enter again. (Navigate the menus with the up/down arrows followed by pressing enter. Use the right/left arrows to highlight an option.)
If the disc was finalized, try a different brand of DVD+R or a DVD-R disc. I've seen some DVD recorders that don't work well with some brands or types of discs. (The same can happen with computers - burning a coaster.)
The manual is available here: .
I hope this helps.
Jan 25, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
I have an old emerson TV/VCR (Digital Tracking VHSHQ) The TV works fine, but when I put a tape in it is ejected and part of the tape stays inside, but can be pulled out.
Try a VHS Cleaning Tape Cassette. Follow it's instructions. If no better result it's not worth throwing away money on having repairs done but better put toward, if you can afford to, buying:
Option 1. A VHS/DVD player (combo as these are known) and plug that into the Emerson AV input.
Option Two: A VHS/DVD twin recorder combo deck - and plug that in.
Then start on copying any VHS tapes you cherish to DVD on this device.
Option Three: Forget the Emerson except for just using as a TV and buy a new TV with DVD player built in - the latest type of combo.
(I'm having to guess whether you've just used tapes to watch or record and watch)
Sep 26, 2011 | Televison & Video
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Nov 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Recording Error -- E7
When I bought my emerson ewr10d4 about 2-3 years ago, the machine only recorded on disks that were rated at 2x or 4x speed. And it didn't accept off-brand disks, it only liked the major brands like Maxell, TDK, Memorex, Sony. I learned this quirk the hard way. Eventually, when I called the 1-800 number, they sent me a disk to upgrade the recorder to 8x speed (and it was very simple to do - basically just pop it in). Helped a lot, although this year most disks in stores are 16x speed, and as of a couple months ago (November 2008) emerson didn't have a newer up-to-date upgrade available. But if you didn't do the 8x upgrade yet, call them and start there. It's a small improvement, but an improvement nonetheless. By the way, if anyone wants to buy some lesser-known chinese and japanese-brand disks, I may be able to help!
Dec 28, 2008 | Emerson EWR10D4 DVD Recorder
Cannot start dubbing
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Jun 07, 2008 | Televison & Video
VHS to DVD Dubbing Problem
I have the same problem. I saw a solution that said I needed to set my cable to a non-premium channel like NBC, ABC, PBS, CSPAN in order to allow the dubbing to occur without the +VR problem. At first, I thought it was a stupid solution; but guess what, It worked. I just set my cable box to from HBO to CSPAN,restarted the dubbing from VCR to DVD and it worked. Now the question is: Why do I have to change the channel when I'm dubbing from VCR to DVD?
This worked for me..still trying to figure out why it worked???
May 25, 2008 | Philips Magnavox DVD/VCR Dual Player
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DV 2150 Remote Control Codes
If it's not a well known brand, you're likely not going to find a code for it. I've heard of Go Video, but I don't think it's a very popular brand. (I could be wrong on this point)
Codes don't exist for every tv/dvd/vcr/surround system.
If the remote you bought doesn't have your dvd player listed, then you're probably out of luck.
If it's a very expensive universal remote (like $50-$100) then you might find either a code or a firmware update for it on the manufacturers website.
If not, try every code the instructions list. If you're lucky, one of them will work. If not, c'est la vie.
Feb 13, 2008 | GoVideo DV2150 DVD Player/VCR
EWR20V5 DVD Recording Error
The disc must be DVD-R with an R4.7 under the logo and they MUST be 4X or 8X specific .... the cannot be 1X to 8X or 1X to 16X or note up to 16X .... the disc box must state 4X or 8X ONLY .... and yes they are hard to find for sure.....
Aug 24, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
