Error 110 primary pairing error
I am unable to view any channel with the set top box . Gives a error nos 110.error 110 primary pairing error
  • 127 Answers
Call your provider for the box
Posted on Nov 03, 2012
5 Suggested Answers
  • 159 Answers
SOURCE: I recently purchased an LG
Hi, The set top box will more than likely have two coaxial connectors ( threaded/ribbed pieces of metal ) coming out of the back. also three R.C.A. connectors-these will be smooth and be colored yellow red and white. one of the coax connectors will say " IN FROM ANT> or CABLE IN) the other ( OUT TO T.V. ) hook up your dvd recorders " ANTENNA " input to the set top box's ANTENNA output. If your D.V.D. recorder doesn't have an antenna input then hook up the recorders audio/video input to the set top box's audio/video output. then you should be good to go. If you buy a H.D.T.V. tuner to receive FREE H.D. programming it may be possible to hook up to recorder with H.D.M.I. cables.( those connections resemble slots ) I hope this has been of some assistance, good luck, Prodzilla.
Posted on Apr 02, 2011
alpug
  • 1961 Answers
SOURCE: i have rescanned my digital
If the channels were missing you may need to clear your box or tv's memory before rescanning again for available channels.
Do this steps:
1. Switch off the equipment and unplug your aerial (antenna)
2. Switch on the equipment and go on the retuning (scanning) of channel process. Your TV should will display a message that no channels have been found. (This is because the aerial is not plugged in.)
3. Switch off the equipment, plug the aerial back in and switch on again.
4. Repeat the retuning process - this should find all the channels available.
Alp
Posted on Oct 18, 2010
  • 67 Answers
SOURCE: I'm trying to set up
try using the number keys on control an manually program numbers in that way, if you select auto tune, it will only try to program any channel it gets signal for, once you type the numbers in that way, it should ask you to save that channel number, in which of course you select yes... try that, also refer to owner manual or mfg website.
Posted on Oct 17, 2010
  • 3 Answers
SOURCE: I just bought a teac
I find that with my HDB849 I have to be very carefull with the positioning of the aerial/rabbit ears to get all the channels to (ABC, 7, 9, 10, SBS and their sub cahnnels) to recieve them at all. Also once you get all the channels it is prone to digitization or pixilation at times due to bad weather/very overcast days.
Try the Teac.com.au for a firmware upgrade as this also solved not being able to view avis & images, listen to mp3's etc.
Overall the majority of reviews say the HDB849 is to be avoided.
Once set up correctly through trial and error and an absolute shitload of patience and re-tuning it seems to operate fine. Just pray you do not get a power outage or you have to start all over again.
Last point, try the teac 1300 number in Australia (or relevent country) and harras them for info whilst trying to stay calm and nice with the unlucky "tech support" person
Posted on Apr 17, 2011
F2-1000T Digital Set-top Box.
There are three ways you can connect a DVD player to a TV. Component video gives the best picture quality, but requires 3 cables for the video signal alone. S-video needs only 1 cable but it isn’t as good as component video. Composite video is the easiest connection to make, but gives the lowest picture quality.
Aug 05, 2008 | Televison & Video
I have a panasonic DMR-EZ48V and on the HD channels it says unable to decode HD!what does this mean and how can I get the HD channels to work?thanks
Unable to decode HD is a common banner display message with these combos. It simply means the unit is not engineered to process HD signals. It is a model series limitation; not a fault as such.
This model incorporates a SD (standard definition) integrated digital tuner. It is a major pain in the proverbial not being able to receive HD, and not being able to skip them in any setup menu.
The only thing you could really do here is connect an external HD digital set top box (which would also contain SD channels) directly to the recorder's AV inputs at the rear, and then selecting the appropriate input on the combo unit to suit the source. You could then choose whether to view/record HD or SD via this method, rather than use the unit's built-in tuner.
Works just as well, with minimal error, depending on the signal strength and type of DSTB used.
It's crude, but cheaper, and does not require repairs or messy wiring.
Jun 03, 2011 | Panasonic Televison & Video
I just bought a teac HDB849 set top box and when I do the automatic channel search I only get 9 digital, GO and Gem. No other channels are found. when I manually key in 72 for 7two or any others I get...
Feb 08, 2011 | Televison & Video
How do i put it on channel three manually?
If the remote to your box can be paired with your tv then you should be able to fix this problem simply by pairing digi remote with tv and while in tv mode on remote, hit the input button. That should change tv back to cable/antenna setting so that you may access channel 3. Hope this was helpful.
Jan 27, 2010 | Symphonic T19WF 19" TV
Unable to record any BBC channels on tvonics dvr
I had this problem and did 'Menu' then 'Settings' and 'Reset set top box'. This will lose your channels and timers, but the recorded programs will still be there. After I did this I could record again on BBC!
Jan 07, 2010 | Televison & Video
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Unable to view fullscreen in hdtv
That is the way HDTV is viewed on many screens as a wide fromat. So you will get top and bottom non-viewable areas. It is the width that gives the full imagery for that format. To have the screen filled you would get a standard 4:3 format like standard TV. HD is a 16:9 format so it is much wider.
Sep 22, 2008 | Panasonic CT-32HX40 32" TV
Drive is not accessible. I/O Device Error
Method 1: Change the transfer mode for your CD drive in IDE Channel Properties
1. Click Start, right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Device Manager.
3. On the right side, expand IDE ATA/ATAPI controllers.
4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK.
If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
• Primary IDE channel, device 1
• Secondary IDE channel, device 1
Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
OR
Make sure that all cables are connected correctly
If you have another cable, try to use it. For USB devices, try to use another USB port. If it is internal dirve is there then Reseat it that means remove it and reinstal that
Then Set the BIOS as Default for that restart the system and before windows screen it gives the instructions how to boot in setup once you are in setup, on the bottom it says press F9 or F10 to set as default; different BIOS have different options so do the as the on screen instructons says.
OR
Try to access the media or device on another computer; try it on your friend or family computer
if it is not working contact your H/W Vendor
Aug 14, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Televison & Video Logo
343 people viewed this question
Top Televison & Video Experts
Electro Med Services...
