Question about Xerox CopyCentre C123 Black and White Copier
Xerox Copycentre C123 Creating a Ghost Image
When trying to make copies the intended image appears weakly on the duplicate, along with text, etc from previously copied pages. There are also random specks of ink that appear on the paper. Does something need to be cleaned? Any suggestions?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
YOU HAVE TO LOG A SERVICE CALL.YOUR HEAT ROLL HAS TO BE CLEAN
Posted on Nov 30, 2009
  • 239 Answers
I read the other possible answers to this problem.
Also, make sure the paper you have is of good quality. If the paper has been sitting on the self (unwrapped) the paper can have more humidity, which can cause copy quality problems.
Make a copy and check the paper. Hold the paper in your hands and see if there are bumps or low areas on the paper. The paper should come out of the machine pretty much flat. Sometimes the paper might have. What is called "Ripples", "Dimples" or low areas on the surface paper?
The first side might copy ok, until the second side is copied.
Try a new fresh **** of paper, and of a different brand and better quality.
Some Ink Jet copy paper will not work on a Xerographic Machine. Make sure the paper that is used on the Xerographic machine has Xerographic paper on the lable.
Also, take a paper and cover the first 1/4 of the edge of the glass and make a copy with the platen glass cover open. The first part of the copy will be blank, leaving the rest of the copy black. The whole black area should be "Black", with no light deleted areas. When area that is black, it should be a nice "Black Image." This will give an indication the drum and developer housing is working properly.
The machine also has a image bias roll. If this part has not bee replaced in a long time, it might be possible the black bias roll (Located on the Side Door) may also cause a problem.
Provide us with more information once these solutions have been applied to see if the problem has been corrected.
Posted on Oct 26, 2009
  • Gilbert Gonzalez Oct 26, 2009
    It was written as "Fresh **** of paper", unopened paper still wrapped.
    Novelist:
  • 126 Answers
First place an original on glass and make a copy -- mark #1. With that same original on the glass, move the exposure all the way light and make a copy -- mark #2. Again with the same original on the glass, move the exposure all the way dark and make a copy --- mark #3. Place #1 in the middle so the the copies read --- #2, #1, #3. The #2 should be the lightest and #3 being the darkest. If #2 is darker than #3 you have a developer problem and you need to call for service. If #1 and #2 are bad and #3 is a good copy your machine probably just needs a good cleaning, mainly the optics and charge units. If all 3 copies are still poor with the speckles, your are looking at the PCU ( photo conductive unit) also called the drum unit. You can order this unit online -- it is a customer replaceable item.
Posted on Jan 04, 2009
How do I turn off copy-card default on xerox copycenter c123
http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
Jan 17, 2014 | Xerox CopyCentre C123 Copier
Hi, my syncmaster p2270 seems to have some kind of focus issue. Everything is sharp, but to the right of the visuals on screen there is a duplicate, reflection of whatever is being displated on screen....
Hi Jonhy, on the pc , try this steps:
1. At the mainscreen mouse rigth click and go to Properties
2. Go to Definitions and Advanced
3. A window with graphic board's properties will come up and the choose 3D setup/config (depending on graphic board mark)
4. Change from Direct 3D to OpenGL and then Apply and OK to close.
This procedure is to change from hardware aceleration to software aceleration of image on screen. As that it will be sent only one kind of image definition from the pc to the screen with no repeating or mirrowed data. Hope it will helps you.
Nov 04, 2013 | Samsung SyncMaster P2270 22 inch Monitor
How do I do a password for the machine Xerox CopyCentre C128
Click on the link below and select to view the Xerox CopyCentre C128 owners manualm inside the manual will show you how to set the password
http://www.support.xerox.com/support/copycentre-c123-c128/documentation/enus.html
Dec 19, 2010 | Xerox CopyCentre C128 Black and White...
CopyCentre C123 Copier Copier: CODE 116-331...
It may be a defective Main System Controller board 160K91660 or Hard Drive 960K01120.
There is a diagnostic which requires the Xerox Technician's Laptop to test the Hard Drive.
You might get lucky just reseating the Hard Drive.
Whit
Item, Inc.
May 17, 2010 | Xerox CopyCentre C123 Copier Copier
My Xerox Copy centre C123 shows error code 124-315 pls help
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
  • [700-600]
  • [700-601]
  • [700-602]
Feb 11, 2010 | Xerox CopyCentre C123 Copier
Xerox CopyCentre prints out faint copies. DIrty?
You have a dirty laser, I will tell you how to clean it when I am awake.
Mar 20, 2009 | Xerox CopyCentre C20 Black and White...
Copying with a copycentre 255
Go to www.xerox.com , on the home page click Support and Drivers.
IN the search where it asks for a product name or number type in 255.
Then select the Copycenter 255 Documentation.
Then select either the QUick reference guide, which is most likely all you need. or download the training and information program.
Jan 01, 2009 | Xerox CopyCentre C123 Copier
Copies have ghost image
yes. although I would first check the fuser unit. It is located the exit side of the copier. let the copier cool down before handaling the teflon fuser roller. The upper roller has a teflon coating, if it is worn the image will not transfer properly to the paper thus leaving a duplicate / ghost image. Good luck
Nov 24, 2008 | Office Equipment & Supplies
Xerox CopyCentre C123 Black and White Copier Logo
225 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
