Question about Kenmore 24032\24036 Top Load Washer
Remove lid of top loading washing machine Kenmore 110.92575110
How do I take the lid off? It looks like there are four screws, two each side, but the rear two are blocked by the control console. There is only an inch or so of clearance for the back two screws. Is there some way that the lid comes off without removing the back screws?
  • 198 Answers
Remove 2 screws that hold the console in place. Most are at the rear corners of the console. Pull console forward and up and tilt back.There are 2 brass clips holding the cabinet in place. then the cabinet can be removed by tilting forward and away from base. there is no reason to remove the lid.
Posted on Jan 05, 2009
I need to remove the lid as well. And yes there ARE reasons to remove just the lid and not the cabinet. I have a rusting area I want to refinish and removing the cabinet doesn't help that at all as it is under the lid. Yet the few places this question is asked people are saying how to remove the cabinet. I love how other people decide what you "need" to do.
Posted on Feb 09, 2010
We need to replace the lid switch on a Kenmore Elite Washer...how do you do that?
Look on the back side of your control panel.Remove the screws from that panel you will find documents about your Kenmore..
Sep 17, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I want to replace the door switch on a kenmore 80 series top load washing machine but i don't know how to remove the console cover
on the back of the console there should be 2 screws,, one on each side in the corner,, looks like they have little plastic tabs over them,, unscrew these and slide the console forward then tilt it back,,, to get to the lid switch remove the gold looking latches and tilt the whole body of the washer forward
Jan 21, 2011 | Kenmore 22422 Top Load Washer
Working on a Kenmore 80 series (11020872990) washing machine, do you remove the rear panel or the front/sides panel?
no don't touch the back at all.unplug it,then pop off the white end caps on the console and remove the two phillips screws,lift up the console,unplug the lid switch connection in the top middle and with a screw driver pop off the metal clips,just stick the screw driver in the hole and on top of the clip and just push towards the back wall and it will pop out,then open the lid and tilt the frame forwards and back at you and remove the hole outside frame.what problem are you having?let me know how you make out
Oct 16, 2010 | Kenmore 22642 Top Load Washer
How do I open the top lid to get to the lid switch on a Kenmore 70 series washing machine?
Remove the screw on both sides of the control panel . Pull the panel foreward and tilt back . Unplug the plug coming out of the cabinet and using a flat head screwdriver , pop the clip on both sides thru the slots closest to the front of the cabinet . Tilt the whole cabinet foreward . Do not try taking the lid off the washer .
Aug 03, 2010 | Kenmore 24032\24036 Top Load Washer
My Kenmore 20902 washing machine lid is rusted. I...
Hello, Guest who?
Getting the lid off of your Kenmore is simple. Raise the lid. At the bottom on each side are a pair of screws that go through the lid and attach to a reinforcing bracket on the inside. Take these screws out, remove the bracket, do the same for the other side. A small bowl or ziplock will keep these small bits from getting away. When you have repainted or replaced the lid, insert the bracket with the loop down, and insert the screws from the outside through the lid.
Done!
May 19, 2010 | Kenmore 24032\24036 Top Load Washer
How do I replace the lid switch on kenmore top loading washer 23902? I can't seem to remove the back panel of the washer.
REMOVE THE 2 SCREWS ON TOP DOWN AT THE BASE OF THE CONTROL PANEL, SLIDE IT FORWARD A BIT AND LIFT IT UP IT IS HINGED IN THE REAR. NOW REMOVE THE TWO BRASS LOOKING CLIPS FROM THE TOP AND REMEMBER HOW THEY GO BACK UNDO THE LID SWITCH CONNECTOR(IT LOOKS LIKE IT GOES THROUGH THE TOP DOWN INSIDE). NOW GRASP THE CABINET AND PULL TOWARD YOU TILL THE BOTTOM DISENGAGES FROM THE WASHER BASE.NOW YOU CAN CHANGE THE LID SWITCH
Apr 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine filling with water not finishing cycle
probably just a bad lid switch or best case loose hinge screws if lid switch is located on right side of lid opening try pressing it down with a pencil or small screw driver if works replaced lid switch by removing console screws under end caps or if newer modes switch located under rear hinge area remove console by pressing clips at lower edge each end of console ..remove brass colored clips on older model and pull cabinet or newer model switch is mounted to top of cabinet under console
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Not spinning after wash cycle
remove the 2 console screws one on each side of front or they may be on the back of console,flip it up and you will see the lid switch jack on the washer in the middle,unplugon the washer side you want two cut the 2 outside and wire nut them together,this will by pass the lid switch,plug back in,put console back and you should be good to go-mike
Nov 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing machine
ck lid switch also ckd hinge screws that looks like newer moder with switch under left side of console try pressing left rear corner of lid or listen for clock when lid is shut slowly
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
Replace lid switch kenmore mod# 110.29902200
remove the two screws in the top of the console they will be in the rear left anmd right side
then flip up the console and remove the 2 spring clips and the lid switch molex plug the cabniet will come off tilt forward and pull out you will see the lid switch running on the underside
Mar 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
1,277 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
