What is cost on replacing hall sensor in lg wm 0532hw washer
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
It is around $20.00 You may order it here.
Below is a video to show you how to replace the sensor.
Posted on Nov 03, 2012
4 Suggested Answers
  • 1531 Answers
SOURCE: LG WM-2277HW Front Load Washer. I am trying to remove the big nut
the best way is to have some one hold the drum from the front and turn the nut. it can also be done sometimes by turning the drum in the opposite direction and then pop it with the wrench. not the best way but it works.or you can hold the stator assy with one hand and tap your wrench with a hammer.i hope thia was helpful,would like to here how things worked out.
Posted on Jan 22, 2010
  • 353 Answers
SOURCE: Goes into rinse stops then starts making a loud Lg wm 0532hw
could be something stuck in the pump
Posted on Mar 02, 2010
heatman101
  • 43501 Answers
SOURCE: OE for LG WM-0532HW
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Posted on Nov 16, 2010
Error le lg washer wm0532hw
Most likely motor position sensor (also known as hall sensor). Under $20 part. Easy fix. Check out videos on repairclinic.com or appliancepartspros.com.
http://www.ebay.com/itm/LG-Electronics-Washing-Machine-Rotor-Position-Sensor-Assembly-6501KW2002A-NEW-/252990897358?epid=710134311&hash=item3ae76ebcce:g:az0AAOSwnLdWsMSa
Jun 21, 2017 | LG WM-0532HW Front Load Washer
Lg front loader washer WM 0532HW doesn't spray water anymore
u could try running a cycle or two with a mixture of 1 part vinagar to 3 parts water and see if it cleans out use hot water
Feb 26, 2013 | LG WM-0532HW Front Load Washer
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
LG WM 1485FHD with LE error code. Stope washing after 5 or 10 mins and can't get it to complete cycle
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | LG WM-1485FHD Front Load Washer
How can I make the water drain from my LG WM0532HW washer with an LE code. BTW- it's had the hall sensor and the main board replaced already.
You can turn the power on, and hit the spin speed button, and then start it. It should drain out.
If your still getting an LE error, and already have replaced the Hall sensor, it's most likely the Stator. If you know your date of purchase, this is most likely still under the 7 or 10 year warranty. Meaning LG pays for the part (over $100.00+),
Mar 07, 2011 | LG WM-0532HW Front Load Washer
LE SHOWS AGAIN THIS IS THE 3RD HALL SWITCH. HELP.....
i had this problem about 6 months ago at a customers house .we ended up changing motor and hall sensor, could b same problem on your unit. get windings checked b4 you replace hall sensor. it might save u money. please reply 4 more help if needed.good luck
Mar 27, 2010 | LG WM-0532HW Front Load Washer
OE for LG WM-0532HW
heatman101
Jan 31, 2010 | LG WM-0532HW Front Load Washer
Le error code
IE means that it is taking too long to fill up.
May 28, 2009 | LG WM-0532HW Front Load Washer
Hall sensor
No. Actually, the Hall sensor, part number 6501KW2002A, is covered by a 7 year part warranty.
Dec 10, 2008 | LG WM-2277HW Front Load Washer
Replacing hall sensor
The hall sensor is located in the back of the washer.  You need to get through the back panel to get to the hall sensor.
Jul 11, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
