Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
When you switch it on it cuts out the main electrical supply
When connecting the mop to the mains, it cuts out and also trips the main elec supply
    Top Expert:
  • 14,553 Answers
You have a dead short in the unit---don't keep trying that or you may have worse---either it is possible to repair or not---replace unit if in doubt.
Posted on Nov 03, 2012
My H20 x5 steam mop keeps tripping the electric I have changed the fuse but this still keeps happening please advise?
Please stop using the mop before you have the thing catch on fire, or even your house/apartment.
What may have happened is the steam/water may have gotten in to the motor some how and is shorting it out.
Jul 11, 2016 | H20 x 5 Mop
Circuit breaker trips with shark steam mop
figure out how many amps your circuit breaker is
then figure out what appliances are running from that circuit
if you are under...then your mop is faulty
May 25, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Henry Hoover cut out and will not work. Emptied bag and replaced fuse but no success.
If no burning or smelling, maybe nothing to do with motor, and if caused by the safety cut-out, it will need about an hour to cool down, and then check filter, bag, and drop coin through hose, pipes and the floor tool, to check for blockages and to stop it running hot. Damaged cable, worn carbon brushes, broken electrical rewind electrical contacts or even the printed circuit board (later models) are the most likely causes.
Jul 08, 2011 | Hoover Vacuums
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
How to rewire a panasonic vacuum cleaner
Once you have taken the handle off and the front plastic cover below the handle at the front and above the bag/bucket holder, you gain access into the power cable and switch connections.
One wire will disconnect easily, the other won't, so instead of trying take this wire out of its connection where many others are from the switch and the motor, cut it on the mains lead before it enters the connection and reconnect the new mains lead wire with a **** or block connector, the other should connect normally with a spade connecter,making sure its will take the amperage of the v/cleaner
Hope this makes sense!
Sep 18, 2009 | Vacuums
As soon as I plug Shark steam cleaner (S505UK) in to mains it trips all the power in the house out. I am using a 15amp extension lead. Are there any user servicable parts or repair centers in the UK?
When the main trip cuts out it indicates current leaking to earth within the guilty machine. In machines that combine electricity and water in close proximity (like yours) this problem is almost always caused by some electrical component getting wet.  I'm not familiar with this particular machine, but doubt if there are any user-serviceable parts. If there are any covers you can remove easily, you might try just exposing the innards and make sure they are dry.  If you can get inside, a gentle blow with a hair dryer might help.
As for repair centres, what part of the UK are you in? The place where I work is in south Oxfordshire, and we're always happy to have a look at problems like this... but no guarantee at this time, of course!
Aug 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vax 2000 trips electrics
Try the reset drive belt brush button - you'll find it underneath the main power switch on the handle. Also check the brush isn't clogged, by the sole plate by tipping it over and undoing the screws on the bottom place where the beater bar is.
Apr 11, 2009 | VAX Appliances Vax X5 Bagless Upright...
When turning on the unit blows the fuse every time
you need a 60amp to run this have a quilified elec in stall
Feb 12, 2009 | Polti Vacuums
Main Vac No go
Hello jb1720.. Here is a link to the users manual... they do not identify the internal electrical components within your vacuum but they do provide contact information ( phone numbers etc). In all probability, you are correct in your assessment that you have an open thermal fuse ( probably non-resettable) in series with your electrical supply line. If you have a local appliance repair place near you, I would take the part with you and see if they have a replacement readily available ( which they probably will).. That may be the fastes way to get one.. Or.. you can use the contact info above to speak with a rep from Eureka.. Hope this helps you..
Oct 02, 2008 | Eureka 437AZ Bagless Upright Vacuum
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
138 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
