Question about Epson STYLUS R230 InkJet Photo Printer
Parts inside your printer are at the end of their service life. See your printer documentation
  • 673 Answers
This usually happens when the waste pads become full and need to be replaced.
You can try to do it yourself like this guy did on his printer:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
you can actually just use the software to reset the printer but eventually the pads will overflow and start to leak.
The last option is too take it to Epson and ask for a quote.
Posted on Nov 03, 2012
SOURCE: service life has ended on my epson stylus r320 photo printer
Thanks for your selflessness Steve H. describing the RESET procedure for the Epson R300 by simutaneouly depressing the POWER, STOP and MAINTENANCE switches.
I checked with Epson, via telephone, and they recommended going to an authorized dealer for ink pad replacement (approximately $100) or buy a new printer ( $150 - $250).
After completing your suggested RESET procedure successfully - I went a step further and mopped up the excess ink that was evident on the 'black ink pad' which was saturated with black ink. I used Kleenex which seemed to mop up the excess BLACK ink nicely, and continued this mopping procedure until there was no evidence of black ink on the Kleenex. There was very little evidence of spilled ink on the color pads.
Time alone will tell. So thanks again Steve - you saved me $100 to $200.
Oh yeah! I LOVE this printer.
Posted on Aug 21, 2008
SOURCE: Parts inside your printer are at the end of their service life. See your printer documentation
I FOUND IT! I KNOW HOW TO FIX:
This saved my printer:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have somespare, just incase. You may also require tissue paper. It is alsorecommended you use protective gloves as the ink will stain your skinfor quite some time. Its really messy, trust me.
  3. Look at the back of your epson c46 there will be a "door" a small square that removes. Take it off.
  4. There will be 1 or 2 "spongey things" inside your printer, remove them. Sounds easier than it it. Can take up to half an hour.
  5. Take the scrap paper with the pads on to your sink, turn on the hottap and hold each one under the tap using the pliers until the waterruns clear. If you have protective gloves on it may be worth squeezingthe water out also. Don't use soap ect.
  6. It is recommended that once you have done this, you let them dry.
  7. Now return the pads back into the printer.
  8. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
Part 2:
  1. Download and install the SSC Service Utility for Epson Stylus Printers.
  2. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  3. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  4. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”. You might have to do this a few times..
  5. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Good luck guys!!
Posted on Apr 18, 2009
  • 400 Answers
SOURCE: " parts inside your printer are at the end of their service life.
Posted on May 14, 2009
Reset the waste ink counter!
Assuming you have completed your modification you can reset your printers waste counter using this method (I did this and it worked on the CX6400) can't guarantee it works on all)
1. You will see big button on your printer like power on (this is on the left
2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
3. first turn off your printer
4. push the b/w + color + stop buttons together and hold
5. push the power on button and hold (so you'll now be holding down 4 buttons together)
6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
7. release all the buttons
8. push the color button (once)
9. turn off the printer
10. turn it on again
After this one may need to reload the printer driver and locate the printer!
Posted on Oct 26, 2009
Epson stylus cx5500 printer problem
probably refers to empty cartridges
everything has a service life and it could be a possible part that is wearing out and needs replacing
you have 2 options --ignore it untl it stops performing
or get in a service technician
Oct 28, 2017 | Epson Stylus 2200 InkJet Photo Printer
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
How to reset waist ink counter
I have resetter for this type. aicazx@yahoo.com
Jun 03, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Parts inside your printer are at the end of their service life. See your printer documentation.
May 27, 2009 | Epson STYLUS R230 InkJet Photo Printer
May 14, 2009 | Epson Office Equipment & Supplies
PART INSIDE YOUR PRINTER EPSON STAYLUS PHOTO R230 ARE AT THE END OF THEIR SERVICE LIFE SEE YOU PRINTER DOCUMENTATION
Parts inside your printer are near the end of their service life. See your printer documentation.
Mar 09, 2009 | Epson Stylus Photo R200 InkJet Printer
Parts inside your printer are at the end of their service life. See your printer documentation Parts inside your printer are at the end of their service life. See your printer's documentation for details
when i swich on my Printer C43, both the indicator lamp is blinking, and tehn appear the message:
"Parts inside your printer are at the end of their service life"
Feb 26, 2009 | Office Equipment & Supplies
EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
Nov 08, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson STYLUS R230 InkJet Photo Printer Logo
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
