How do I connect the Philips SW8100/37 subwoofer to a non Philips amplifier?
4 Suggested Answers
zoomiezz
  • 50 Answers
SOURCE: i cant connect my subwoofer
welll if your handy with solder then you can just get the rca solderables from radioshack ans some speaker wire solder pos to pos and neg to neg and voila you got some patch cable just make sure that the outside neg- part of the rca matches the neg  lead you want-z
Posted on Feb 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: i have atomic A-8 subwoofer
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Posted on Apr 23, 2011
dunnbiker
  • 8546 Answers
SOURCE: i have a 2 channel
Refer to the applicable Jamo manual.
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/313.aspx
Posted on Jun 02, 2011
I have a Philips PWR2006-37 subwoofer. Can I connect it to any amplifier
you can download the manual here
http://www.docs-engine.com/pdf/1/phillips-pwr2006-37-manual.html
Jul 02, 2016 | Philips Audio Players & Recorders
I would like to connect my Philips subwoofer to my Pioneer multi channel receiver, but the subwoofer's input has only a 15 pin serial port connection. I need an inexpensive and easy solution?
Unfortunately, most subwoofers , like the one you're describing, need a separate amplifier. I don't know the model number of what you're working with but most Phlips subwoofers with that connection need an amp. Now, if you have the rest of the system that was originally with the sub then you can scavenge it's amp. But that's tricky if you don't know what you're looking at. Craigslist has tons of "powered" subwoofers that don't require a separate amp and u can therefore use your Sub Preout from the HT receiver.
Feb 13, 2016 | Pioneer Audio Players & Recorders
Bose 3-2-1 system subwoofer connect to denon avr
The subwoofer is not designed to be connected to a non-Bose amplifier.
Jun 07, 2012 | Bose Audio Players & Recorders
How do i connect a subwoofer to my stero technics su-800mk2 amplifier
You would connect any non-specific subwoofer according to its needs:
passive = to an amplifier channel;
active (self-powered) = per its manual and the capabilities of the source.
Given the lack of a specific subwoofer facility on the SU-800, you need a sub that can be driven by full-range speaker level output. Its manual would describe the procedure. Keeping in mind that most active subs are pretty much the same speaker-level-connection-wise (if they allow it), you could find just about any manual and wit would get you running.
http://archiwumallegro.pl/technics_sua800_mk2_wysoki_model_krakow-998303435.html
Jul 06, 2011 | Audio Players & Recorders
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Feb 10, 2009 | Marantz PM-68 Amplifier
Subwoofer: Active or non active?
Hello Smegboy,
Yes, you are right. This receiver is rated at 100WRMS output in all 5 channels (2-front, 1-center and 2-surround) while in Dolby Pro Logic operation. The subwoofer output is line level only (not amplified), which means you need a powered subwoofer to be connected to this output. A non-powered subwoofer could be used but, you need an additional amplifier connected to the subwwofer output from the receiver to drive it.
Let me know if this helps.
cancerags
Dec 29, 2007 | Technics SA-AX710
How do i connect non passive woofer
This receiver can only take a self powered subwoofer I'm afraid. You could get a power amp and power the sub like that but in the long run I really think you would be happyer to get a new subwoofer. Good Luck
Jun 07, 2007 | Pioneer VSX-516-K/S Amplifier
408 people viewed this question
 Grubhead
Grubhead
