Question about LG 32LG30 32 in. LCD HDTV
Ci module removed - LG 32LG30 32 in. LCD HDTV
My bush 32 inch LCD keep displaying on the screen (common interface module removed) when ever I am watching the TV. I don't have the receipt and the box it came in with so Argos or bush helpline can't help...
I found this far-from-definitive answer more of an explanation, than a solution.
http://community.screwfix.com/threads/ci-module-what-is-it.47854/
Possible Solutions:
~If you removed a card from the PCMCIA slot of your TV, put it back in.
~If you recently changed the Pay TV channels you subscribe to, either added OR removed some, contact your TV channel supplier, it may be a problem on their end.
May 27, 2014 | Televison & Video
Service center saudi arabia
Have anyone tried to repair this TV? Have anybody removed CI module out of it? If not, there should be some loose contact with this module connections. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 09, 2013 | LG 32LG40 32 in. LCD HDTV
Ci module
Known as a common interface module. Allows you to sign in to scrambled channels. That's th eshort explanation.....
May 28, 2013 | LG Televison & Video
No spark 1987 gmc half ton 4x4 305 ci
ignition module in the distrb or a bad module
Oct 11, 2012 | 1987 GMC G1500
My tv is LG 42LG2000. got a CI Module with tv card from local tv company to be able to watch on more than 60 channels. tv was able to detect CI module, tv card activated, but cant see where i can enter...
kindly check with the company who you got the module from..i am sure they will be able to help as they have a working knowledge of the module along with manual.good luck.
Sep 25, 2011 | LG 42LC2D 42 in. LCD HDTV
What is No CI Module ?
Hi
CI stands for common interface, there will be a slot on the side of your tv for a CI Module to be inserted, this allows you to view encrypted channels (such as ESPN) that you have to pay for using servces such as topup tv (uk).
It sounds like you have being trying to watch a encrypted channel without a CI Module inserted, this would most likely be the cause of the error message you are receiving.
Hope this helps
Mar 07, 2011 | Hyundai T236W LCD TV
Will not start type III 2.0 C.I. 16 inch chain saw
Remove the spark plug and test for snappy, blue spark. If nothing, try a new plug. If still nothing, remove the left side cover to expose the flywheel and ignition module. Remove the wire from the module that goes to the ignition switch and retry for spark. I now ok, look for problems with the ignition switch or possibly, the wire is grounding out somewhere. If still no spark, replace the module itself. Use a thin business card for a pole gap gauge, rotate the magnets under the module, set the gauge in the gaps, loosen the mounting screws and allow the module to stick to the magnets. Re-tighten the screws, and rotate the flywheel to remove the card from the gap, then turn the flywheel one complete revolution while checking that the pole gap does not close up at any point. Recheck for spark. If now ok, place some fuel mix in the plug hole and pull through--it should pop several times and maybe even run. If you get only pops, then check the fuel system lines and the filter in the tank. Make sure that the air cleaner and muffler are not plugged. Hope this helps!
Jun 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
LG 32LG30 32 in. LCD HDTV Logo
79 people viewed this question
Computer Repairing
Computer Repairing
