Question about Frigidaire ATF6000ES Front Load Washer
Wont ring water wont drain - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, the unit could possibly be experiencing an issue with either the pump or timer. Contact a professional to move forward accurately.
Posted on Nov 03, 2012
My Toyota Bakkie 2000l vvti wont start after fitting new o ring.... Water leak
What O ring? On cylinder head? Do you see water floating in oil after draining oil pan? If water enters exhaust system, catalytic converter (assuming there is one), maybe clogged.
Jan 27, 2015 | Toyota Cars & Trucks
2002 Ford F-350 Super Duty, w/7.3 Diesel, I have a leak where you drain water from the Fuel Filter, I think the "O" Rings are cracked or completely gone, Can I not just replace the "O" Rings that are
You can use "o" rings for this problem or if the thread is still good you can a soft copper/ washer. If the problem is in the drain bit itself and the thread is good in the body you can use a short bolt and a fibre washer to seal it off. It only means removing the bolt to drain the water when it needs to be done . The water in the fuel comes from condensate from the hot fuel cooling down and one way to prevent the condensate from appearing is to not shut down on
anything less than 3/4 tank of fuel (Fill up on the way home ). With less air space there is less air that has water vapour in it Any way go to a ford wrecker if the drain plug is not repairable and get one from there.
Jan 14, 2014 | 1994 Jeep Grand Cherokee
I wont to replace the sealant from around the tiolet waste pipe, what is the best way of doing this?
turn water supply off to toilet and disconnect water line from bottom of toilet tank. flush toilet to drain tank, use towel to soak up water inside that didnt flush.remove the 2 bolts ( 1 on each side of toilet), lift toilet up and move to one side and lay on it side, scrape off old wax ring from bottom of toilet, scrape off excess wax from pipe on floor. install new wax ring over drain pipe. stand toilet upright and lift straight up over drain hole and reset slowly to make sure each bolt goes through the holes on toilet, replace nuts and washers on toilet and tighten. hook water supply liune back up and turn on water.
Aug 30, 2011 | Home
I INSTALLED A NEW TOTO #51 TOILET ,EVRY THING WORKED GREAT, JUST WONT STOP RUNNIG WATER .ITS NOT OVER FLOWING. YOU CAN HEAR WATER RUNNIG OUT OF TANK, I PUSHED DOWN ON FLAPPER TO GET BETTER SEAL DIDNT ...
There are only three places tank could leak without running on floor; 1 Flapper valve, even though you push on it, theres a possibility it might not be saeling right especially if it has a rubber ring that slides down over overflow tube. Tjis will sometimes contort the shape of the flapper. If it has such a ring and also has the ears to hook on to the hooks on overflow drain assembly, take the flapper out and cut the ring off . 2 if the overflow tube is not sealed and/or carcked below the water line, it will leak. 3 If the main drain assembly, where it goes through tank, is not sealed, it could possibly be getting past and still not leaking past seal between tank and bowl. Some fill valves will run a couple of seconds intermittantly and have to be adjusted but will not run all the time.
Apr 07, 2011 | Home
Frigidaire front load washer LTF2940FE0 wont drain
That loud noise is most likely debris bouncing around inside your water pump. Pull the 2 hoses off and try removing it by hand, or un-bolt it from the floor pan and tip it sideways to shake any small objects out. I found a mans wedding ring in there once.
Mar 18, 2010 | Frigidaire ATF6000ES Front Load Washer
Have a mah4oooaww maytag frontloaded and sounds like the water is not draining removed pump and is clean and drain water still inside drumHow do i get rid of the water in drum
jf you have removed the pump i can assure you the water is out
what you may be hearing is the liquid balance ring on the tumbler front
if it sounds like running water when you turn the tub, it means your balance ring is working'
it is there to keep the machine balanced and is sealed in the ring
Oct 20, 2009 | Maytag Neptune MAH6500A Front Load Washer
Door wont open
The door switch could have stuck closed. there is a way to open it up manually.
if you can just access the water pump filter cover, and at the back part of the door switch you will find a plastic ring attached to the door switch, pull it down to open the door.
drain first the water if there is water left in the unit by slowly opening the water drain filter cover and drain the water slowly.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Washing Machines
I have a hobart dishmachine model# CRS-66AW after filling dishmachine water will not stay in the wash tank, sometimes half of the water drains out. we have replaced the o-rings on the drain plug recently....
Which tank is loosing water?
Number 1. Make sure all curtains inside are in place.Curtains help keep the water in the proper tank. For example, curtains are missing between prewash tank and wash tank, the wash tank water could be significantly splashing into prewash tank and out the p.w. tank overflow. Are you ruling out the drain because you replaced o-rings? Look at the floor drain as machine is running. Do you see a large flow of water going down drain? There is a drain heigth adjustment on the drain lift. Mabe the drain stopper is not dropping far enough.
Mike
Mar 07, 2008 | Dishwashers
Frigidaire Front Load Washer
most washer door seals when fitted correctly have drain holes at the bottom that allow water to drain from the rings as you call them, this may not be one of those seals and the problem is annoying but there really is no actual cure as such apart from wiping it out after each wash to check if the door seal does have drain holes but is fitted wrong, look round the inner lip closest to the spinning drum to see if there are any holes, maybe higher up or near the top, if there are then it may be possible the seal was fitted wrong (if its not the factory original) the cure then is to replace the door seal and fit correctly some door seals have a large drain hole that is at the bottom that goes into the bottom of the drum (you can't see the pipe normally) this hole maybe blocked if thats the case try prodding it clear with something that wont damage the rubber (use common sense here) hope i have been of some help
Oct 07, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
