Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen What is causing my screen to have a small specs or lines of white to appear?
    Genius:
  • 1,153 Answers
Are the line bright white retrace lines going down screen? If so then screen voltage maybe too high
Posted on Aug 29, 2007
The specs didn't appear until I replaced my projection bulb... might this have anything to do with it????
no the specs or white dots are caused by the DLP chip. eventually the dots will fill the entire screen . replacing the DLP chip usually solves that issue.
Apr 07, 2013 | Televison & Video
White line running through cente of screen
Hi there, If the line appears already from when you switch on your Laptop then it means your LCD/Screen is busy breaking. The white line is normally caused due to loose contacts inside screen and cannot really be repaired.
regards
Jul 29, 2011 | Advent Computers & Internet
A vertical white line appears on my screen
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical white line. Usually screen replacement is the only answer to fix it.
Feb 17, 2011 | Acer Aspire 4315 Notebook
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
White vertical line through laptop screen
The cause is a failure of the LCD, and you can fix it by replacing the LCD.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+5160+LCD&_sacat=See-All-Categories
Instructions are here
http://support.dell.com/support/edocs/SYSTEMS/ins5160/en/SM/display.htm#wp1105699
Mar 29, 2010 | Compaq Presario M2000 Notebook
White horizontal lines appear in the screen
you may just need to reseat the cables. basically all you have to do is take the keyboard bezel off of the laptop and disconnect and reconnect the cables on the lcd. you usually do not need to unscrew anything but a pick would help. Just simply pry it off using a pick or small flatheadd80ef8a.jpg
Dec 08, 2009 | Sony VAIO VGN-CR220E/W Notebook
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
The screen shows vertical line on a white background then when i adjust the screen, it turns completely white. But for me it is when adjusting or applying a small pressure on the screen or even when...
The screen is starting to go bad and needs to be replaced probably. Anytime lines appear it usually means the screen is bad.
Best way to verify this, is to unseat and reseat the lcd cables to the screen and if it still happens then you know the screen is bad, if it doesn't then it was a loose cable.
Jul 06, 2009 | Acer Extensa 5630-6806 Notebook
I have a 1985 Zenith Space Command Color TV. It has developed thin white lines at the top of the viewing screen. The rest of the screen is clear. Is it something small or am I looking at a new picture...
The picture tube is fine.
Those whites lines at the top of the screen are caused by a dry or leaky capacitor(s) nearby the vertical amplifier IC.
Let me know if you require further assistance.
Jul 26, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
158 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
