Is it possible to deristrict an ajs firefox 50
My ped can go 35 mph is there a way i can make it go faster
  • 99 Answers
SOURCE: my 2000 dodge intrepid will not go any faster than
your car now it is in safe mode you have problem with your trans your computer wont allow your car to go faster until you fix the problem your car doesnot have mass air flow what i do first i check for the speed sensor first input and output speed sensor check if the odometer or tach is working too or not
Posted on Aug 08, 2009
  • 60 Answers
SOURCE: My 2000 Dodge Intrepid was not going any faster
have a shop take a look at it this year of vehicle has shift solenoids in the trans mission and could be an electrical problem ,find a shop that works on transmissions and does diagnostics
SOURCE: car accelerates to about 35 mph and doesnt go any faster
mine does the same thing. im thinking O2 sensor, or something in the fuel line like the ful filter or sumthin. i dont know much about cars, but this is what ive been told. try some octane booster for a temporary fix, they have some NOS brand octane booster at O' reilleys that boost the octane 60 points, its not street leagal, but whos gonna know? lol
Posted on Jul 18, 2010
bluesman1956
  • 388 Answers
SOURCE: my 93 chevy silverado 1500
The transmission is slipping. Try having the tarns flushed and new fluid and a filter replaced.
Posted on Mar 19, 2011
SOURCE: does any one know how
how do i deristrict an ajs eos 125
Posted on Aug 15, 2011
My 2004 Rendezvous starts shaking at 35 mph and stop at 50 mph. If I let off the gas the shaking stops. whats wrong
This may a serious problem that may cause you to have a bad accident. Please take into a service shop ASAP and have them check it out.
Dec 09, 2014 | Buick Rendezvous Cars & Trucks
Grinding noise over 30 mph
you would have to find out where the speedomator wire/cable
connects
heres some idea
there is a gear at the end of a speedomator cable
try this 1st hit me back if this dosent work
Nov 01, 2012 | Mazda MX-5 Miata Cars & Trucks
Generic xor 50 deristriction
Read the service manual. It cautions against changing the carburetor jet size since this can cause problems (carbon buildup or overheating). Carbon buildup at the exhaust port is an issue; the manual recommends cleaning it out every 6000 km (4000 miles) to prevent a loss of performance.
The following discussion is based on the assumption that you are trying make the bike go faster than the factory original specifications. I did not see anything in the manual resembling a speed governor, so i assume the limits are set by the engine and transmission parameters. Aerodynamic drag increases as the square of the speed above 20 mph, so anything you can do to reduce drag will significantly cut the power needed at higher speeds.
Probably the most significant limitation to engine output is airflow through the throttle body. Increasing fuel flow at wide-open throttle will only waste fuel on a rich, cooler, dirtier burn. However, there is a maximum amount the cylinder can pull in, so simply installing a larger carburetor may produce only a limited increase in power. Forcing more in (as in supercharging) risks an over-pressure condition and blown engine.
In the ignition system, capacitor charge time may be an issue at higher RPMs. You can decrease this slightly by replacing the diode with a silicon carbide diode (make sure it is rated for the same or higher voltage and current as the original diode). Also, make sure the connection between the magneto coil and ignition circuit is clean and solid. Likewise, check the ignition coil connections to make sure they are good (the manual lists the resistance for the standard coils; you want this as low as possible. Ultimately, the inductance of the ignition coil limits the charge rate, but this cannot be reduced without problems getting an adequate spark. Otherwise, do not try to bypass the capacitive discharge ignition; that's the output of the timing control.
Speaking of timing, higher power engines will typically advance the spark at higher RPM to ensure combustion pressure starts rising at top dead center. Unless your ignition magneto has a centrifugal stator advance mechanism, your engine probably has fixed timing. Modifying this is a tricky business; if you fire the spark too soon you will lose power and risk damaging the engine with detonation.
The maximum RPM shown on the spec sheet is 5000. Exceeding this can damage the engine; the lubrication system may not be able to keep up with the demand for oil flow, and centrifugal forces may exceed the strength of the metal. If the engine throws a rod at high speed, you could easily get hurt. The only way to go faster than the design speed without exceeding the engine speed limit is to install a transmission with a higher top gear ratio. But if you do this, you may find your brakes are inadequate for emergency stops at this speed.
I suggest you would be better off saving your money for a bike designed for higher speeds rather than risking this one on potentially hazardous and damaging modifications. In some jurisdictions, it is illegal to travel over a certain speed (typically between 25-35 mph) on moped or scooter class vehicles.
Sep 24, 2012 | 2009 Generic XOR 50 Stroke
Can i deristrict my 2012 honda NSC vision 50cc
It's not so much a derestriction but is about the only thing you can do to make this ped faster. Using a malossi variator kit. http://www.psntuning.co.uk/scooter_parts.php?prt_id=2411
Apr 05, 2012 | Honda Motorcycles
Steve traveled 200 miles at x speed. Had he gone 10 mph faster, the trip would hav been 1 hr less. What was his speed?
The easiest way for me to do it would just be to work out times in 10mph till i got close so :
10mph = 20 hours
20 mph = 10 hours
30 mph = 6.66 hours
40mph = 5 hours
50 mph = 4 hours
And there you see if he was going at 40mph it would take 5 hours, if he went 10mph faster to 50 mph it would take 4 hours, so the trip would have took 1 hour less.
May 06, 2011 | Office Equipment & Supplies
Car accelerates to about 35 mph and doesnt go any faster
This could be a transmission issue or a catalytic converter issue hard to say with the limited info provided
Nov 05, 2008 | 1992 Cadillac DeVille
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
