Question about NEC MultiSync LCD2690WUXi LCD Monitor
NEC MutliSync LCD2690wuxi screen stays black, won't come on
I was going through the advanced OSM menu on the NEC MutliSync LCD2690wuxi, and clicked on something, I have no memory of what menu item it was (I was still confused from trying the advanced calibration) the screen went black, and that was that. Nothing I've done since - unplugging both it and the Mac G5, restarting the Mac (even though I couldn't see to navigate the mouse to restart and had to use the power-button to power-off), has helped solve it. It just will not light up. The limited OSM I get by pressing Input/Select or Exit just gives me IPM, DVI Selection, or HDCP, so I selected IPM Standard, Digital under DVI Selection, but it just won't come on. The LED glows blue, everything is as it should be, just no screen image. When I start up the Mac it does come on, but only between the grey Apple and the Log-in box, then it goes black again. Please help! Many thanks, Jonathan Tyler
  • Chris Busch
    Chris Busch May 11, 2010
    Sounds like a video option was picked and its swithing over after boot. Any external video connectors on it?
    If so try hooking it up to one and seing if it gives you picture.
I am now in touch with NEC, and hopefully a resolution to this problem will be found.
Posted on Jan 05, 2009
Is there a way to reset the M46 to factory defaults without using the onscreen menu?
No. There is no other way to get it to its factory reset; without entering its service mode. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts. Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Mar 30, 2014 | NEC Multeos M46 46 in. LCD TV
I have a NEC AccuSync LCD5V monitor and the picture on the screen will not extend over the whole screen....the right side has the picture re starting by about an inch
Windows 7 & Vista:
Right Click on your desktop and go to Personalization. Click on Desktop Background at the Bottom of the screen. On the Picture Position drop down menu, click Stretch and save changes.
Windows XP:
Right Click on the Desktop and click Properties. Go to the Desktop Tab. Select stretch from the drop down menu. Apply.
Please Rate my answer. Thank you.
Apr 19, 2011 | NEC AccuSync LCD5V-bk (Black) 15 in. Flat...
NEC PlasmaSync 50MP2 50 in. Television But after looking at the manual I see that I am missing menu options (Option1-4 and Advanced OSM) How do I enable these. This is a hand me down and I've had to get a...
hi mate, did you sort this problem out, i have bought same tv but when u switch it on the rgb2 screen comes up and you cant change it by buttons at the bottom, i dont have a remote either.
what universal remote shall i get and how do i enable the buttons at the bottom
thanks.
fourteen0407@yahoo.co.uk
Jul 05, 2010 | NEC PlasmaSync 50MP2 50 in. Television
Brightness
Hi my name is Roety,
I can help you with your issue ,
there is a brightness adjustment within the video/display properties in windows.  Right click on the desktop left click on properties then Lft clk advanced then look for the adjustment in the tabs. Nvidia and ATI have different setups as does Intel .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 10, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Color calibration
All monitors have a brightness control. Click the menu button and from the on screen menu choose the brightness and set it to your liking. There should also be a contrast control and may or may not be a backlight control. All the user controlled setting are in the OSM.
Nov 27, 2009 | Computers & Internet
How do I fix my screen from being blurry? I have an AccuSync LCD 72vw with AT&T services.
Hello: Try the following:
Signal cable should be completely attached to the computer.
Use the OSM Image Adjust controls to focus and adjust display by increasing or
decreasing the FINE control. When the display mode is changed, the OSM Image
Adjust settings may need to be readjusted.
Check the monitor and your display card with respect to compatibility
and recommended signal timings.
If your text is garbled, change the video mode to non-interlace and use 60Hz refresh rate.
Nov 19, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
I have nec plasma sync 42mp2 but no remote
Usually many plasma's have their controls on the side of the screen including power, so I would check their 1st.
As for getting a remote, harmony (now owned by logitech) makes some great remotes. One of the advantage of their remotes is that they are programmed from the computer by entering the model # of the items you wish to control. So you would just enter the NEC model to program the tv.
May 12, 2009 | NEC PlasmaSync 42MP2 42 in. Television
NEC MultiSync LCD2690WUXi LCD Monitor Logo
204 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
