Question about Lexmark X342N Multifunction Printer - Monochrome - 27 ppm Mono - 600 x 600 dpi
The station name comes up I would like the number to come up instead, it seems to show the option for either, is there a way to change what comes up.
  • Official Brand Answer
  • 3,344 Answers
  1. Obtain the printer's TCP/IP address.
  2. Open your web browser.
  3. In the URL field, type http://MFP's IP_ADDRESS, where IP_ADDRESS is the TCP/IP address of the printer.
  4. Click on SETTINGS.
  5. Click on FAX SETTINGS.
  6. Click on ANALOG FAX SETUP.
  7. Scroll down to FAX LOG SETTINGS
  8. Change the LOGS DISPLAY to DIALED NUMBER
Posted on Nov 09, 2012
  • 1 more comment
  • Craig D Nov 17, 2012
    I got the op address off the machine, I put it into my browser and nothing came up, no idea why. Any other ways to do this?
    ip*
    A bit more details when I put in the ip address I get Oops! Google Chrome could not find "address" I turned off any firewalls, internet is working,... Is there any other way I can get into these settings?
I can't get any radio stations to come in on my 2004 Sequoia radio. The antenna seems to be moving up and down just fine. The screen used to show the artist name, song name and station, but has stopped...
no radio stations: propably Antenna cable is disconnected even if it goes up & down... try check it both ends
screen show: 1st make sure you press the "TEXT" button on stereo panel, otherwise try do self diagnosis (if you have in dash cd changer)... email me if problem still exist
Oct 15, 2010 | 2004 Toyota Sequoia
My E71 shows numbers not names when i receive text messages. How do i change it so it displays names instead?
copy your sim contacts to your phone...by doing this press arrow down ,then option ,sim contacts ,mark all then copy contacts..thanks ,i hope it will help..
if you find this helpful please vote..
Jun 11, 2010 | Nokia E71 Smartphone
My sim card is in and my phone book is showing but my txts show up as numbers instead of the peoples names?
make sure that none of the phone numbers are saved with a "1" in front of the area code - that is usually what causes it to come up as a number instead of a name.
Mar 22, 2010 | Motorola Mobility RAZR V3
CAN'T GET ALPHABET LETTER TO APPEAR FOR STATION ID.
Letters are on the soft pad to the left of the number keys. Very tiny, so look close. You can also lift up the mylar sheet and remove the paper sheet.
Mar 04, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
I want to change the name (My caller ID)when I fax how can I do that It show up as Holy Dreams that name of our former company. I want it to show as our new company. How do I do that
I believe you wish to change the "Station ID" on your MFC-240C. This setting will print out your company name and other header info on your faxes:
1) Press the <Menu> key
2) Press <Up> or <Down> Navigate to "Initial Setup"
3) Press <OK>
4) Note: Your station ID is already set, therefore the machine will prompt you to choose: (1) change, or (2) exit without changing - choose (1) to change
5) Enter your fax number, then press <OK>
6) Enter your company name using the dial pad keys. This may take a little practice. Press the dial pad key the correct number of times to produce your desired letter. Use your (>) right navigation key to advance to the next space. If you entered a letter incorrectly and want to change it, press the left navigation key to move the cursor under the incorrect letter.
7) Press <OK> when finished
8) Press <Stop/Exit> to resume normal operation
There! You should have it. I hope this helps!
Brother MFC 240C Station ID
Mar 03, 2010 | Brother Multi-Function Center MFC-240C...
How do i get my txt to show names instead of numbers
hey, i had the same problem. you have to add a 1 in front of the area code and phone number. (13215556666)
it worked for my i68+
good luck
Aug 11, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
SMS - Recieve number instead of Name
When it comes through it usually comes with the area code and number correct? that is the way you have to save it. Look at the number and if it has the 1+ area code+ number that is the way the phone rconises it and that is the way it needs to be saved. I always save mine to phone instead of the sim since it gives you more options in the phonebook.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 01, 2009 | Dual Electronics N99i Cellular Phone
Caller id now shows number instead of name (new provider)
This is something you could be walked through with tech support. They would need to know what type of system and what cards are in it, in order to program it. ldtsnj.com
Apr 22, 2009 | NEC Electra Elite 32D-1 Corded Phone
Skifi xm
click on the display button until it shows the channel name
Aug 19, 2008 | Delphi SKYFi3 XM Radio Receiver
Lexmark X342N Multifunction Printer - Monochrome - 27 ppm Mono - 600 x 600 dpi Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
