Question about Singer Sewing Machines
Threads overlock on plate and clog up - Singer Sewing Machines
  • Singer Master
  • 7,365 Answers
Try changing the needles
rethread the machine, checking to make sure every thread guide is
used.
make sure the thread comes off the spool or cones freely
take a can of air that you use on a computer keyboard and spay
the air in and around the looper area
make sure to adjust the tension according to the fabric being sewed
Posted on Nov 03, 2012
2 Suggested Answers
  • 1116 Answers
SOURCE: Threads knotted under the plate in the feed dogs.
Some sergers have a threading guide inside the door on the front of the machine.
If you need a manual, please provide the brand & model.
Posted on Mar 06, 2010
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Hi. I have a new overlocker. Fabric got jammed ,got it out but machine now jams at half turn . Could some fabric still be under feed dogs ? How to get it out ?
Hello Jenny hornsey
This may sound traumatic, but there is no easy way to pin point where the tie-up is located. So proceed as follows.
Cut all the threads as they come off the antennas.
Open the front cover and pull-out all the threads by pulling them straight toward the back. If they do not come easily, try moving the hand wheel back and forth by a 1/4 revolution .. this is like a rocking motion. If still not budging, start cutting back the threads and removing them in sections until all the threads are cleared. If this step is still challenging; check that there is no residual fabric or threads still wrapped around the loopers or other part/s of the serger. If so cut them out bit by bit until everything below is cleared.
Great. Now check for threads wrapped and/or jammed anywhere above.
Since the overlocker jammed, it is possible that the needles were bent. This will continue to cause issues in stitch formation. So just to make sure; change the needle/s. Make sure that the correct needle type is being used. Every overlocker is engineered to be used with a specific needle type. The needle type will be specified in the manual and will also appear on the needle package. If the needle types are not the same, do not use those needles.
Re-thread the overlocker and stitch test on a piece of fabric before pressing down on the foot control.
This should get the overlocker back on track and you back to overlocking.
Please let me know how this works out for you.
Happy overlocking
Sewingirl/
Mar 18, 2017 | Sewing Machines
My pegasus industrial 5 spool overlocker type L52-18S1 spec 2x4 dose not overlock in the threads
the machine may need to be taken in to be checked to see if it's
out of time
Jun 07, 2012 | Sewing Machines
Sould i use overlock thead on my brother embroidery/sewing maching
It is, of course, possible to use overlock thread in a typical machine. Generally speaking, you only want to use overlock thread to overlock ("serge"). The reason for this if that while typical all-purpose or sewing machine thread has 3 strings wound together, overlock thread has only 2. When you are using 3, 4, or even 8 threads at a time with a serger, each strand doesn't necessarily have to be as strong as when you are sewing on a machine with only 2 threads. So, you physically could use the thread, yes, but it will not be near as strong, and you will probably have issues with breakage while sewing as well. The cost savings you think you may be saving by using overlock thread (which is, after all, considerably cheaper per yard), well soon be overrun with extra time sewing due to broken threads and overall less quality in your garment as it will be made weaker.
Jun 19, 2011 | Brother Lay-In Thread Serger Mechanical...
Brother 925D - threads do not lock
threads do not overlock stich
Aug 11, 2008 | Brother 925D Serger
Singer overlocker
Most likely is the left looper thread is trapping the needle threads.
Remove the threads and start over in this sequence....
Left looper - right looper - left needle - right needle.
If you thread the needles before the lower looper, the needle thread wrapped over the looper will be under the looper thread and will never be free to form a stitch, so the threading sequence is critical.
Jun 08, 2008 | Sewing Machines
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
