Question about Microsoft Windows XP Media Center Edition 2004 for PC
Where would i find the settings to change picture quailty on my pc
Trying to change computer timing mode to vesa 1360x768
  • Microsoft Master
  • 2,878 Answers
Right click desktop > Properties > Settings > Screen Resolution. Size range is dictated by the video driver.
Posted on Nov 04, 2012
How to make colour best in ps2 game
your tv will have more control of colour/picture quality. but depending on what cable you are using. if you are only using the S-video cable you will get better picture using the Component Video (Y, Cb/Pb, Cr/Pr) cable. change the video output setting from RGB to composite mode and that should improve the picture quailty
Mar 20, 2014 | Sony PlayStation Video Game Consoles &...
Samsung SyncMaster S24B300 is not in optimum mode of 1920x1080 60Hz as it should, but in 1360x768 ocasionally is starting up in 1920x1080 but most of the time in lower resolution mode, could FixYa he
Using our onchip Intel graphics we experienced the same problem, where the aspect ratio was displayed wrong using the native resolution of 1920x1080 at 60Hz while black bars show on the left and right side.
The problem was partly solved by using custom timing settings as you can find below:
Front Porch: 90 and 19
Back Porch: 148 and 22
Sync Width: 42 and 4
Active: 1920 and 1080
Scan rate: (auto 67.5) and 60
Then you just have to move the image down a couple of pixels using the buttons on the display.
Aug 27, 2012 | Computers & Internet
I have recently bought an LG 26LD350. None of the ratio options set the screen properly. The picture is being stretched and a chunk cut off the left and right sides of the picture. Hope you can advise,...
You will need to set the tv to 4:3 ratio or 16:9 depending on the quailty of video you are trying to view. Most cable companies also use settings in their cable boxes that can be changed for output to the tv. You will need to check the video quailty and set the tv accordingly. EX: 4:3 Standard Definition 16:9, High Definition.
Please rate if this helps :)
Mar 17, 2011 | LG Televison & Video
I hook up my pc to lg lcd it always says invalid format any solution
What cable connection are you using? What resolution was the computer sending to the video graphics adapter before you connected the two?
The TV can only support
VGA Resolution: 720x400, 1360x768, 640x350, 640x480, 800x600, 1024x768, 1280x768, 1360x768 or 1366x768
HDMI to DVI: 640x350, 640x480, 800x600, 1024x768, 1280x768, 1360x768 or 1366x768
For best results you should use 1360x768.
Try resetting this when the Input is set to that for the computer. Press Menu and select Picture. Press Enter and select Screen (RGB-PC) (use the Up/Down arrows). Press Enter and select Resolution. Then press Enter and select the desired resolution. Then press Enter again.
If you like there is a Auot-config option in the Screen menu, that may set the TV properly.
If the above doesn't help, use another monitor and check the output resolution and then reconnect to the TV.
I hope this helps.
Feb 04, 2011 | LG 32LG30 32 in. LCD HDTV
What should the display rate be set at for a Viewsonic VG910s. The default is 60 MHz - can it be changed to 72 MHz?
The default is 60Hz (60 cycle, not 60MHz (60 million cycle) for Vertical refreshing rate.
From user manual:
"For the best picture quality set your LCD display timing mode to:
VESA 1280 x 1024 @ 60Hz. "
and here is the warning:
"WARNING: Do not set the graphics card in your computer to exceed the maximum refresh rate of 75Hz; doing so may result in permanent damage to your LCD display."
http://www.viewsoniceurope.com/uk/support/downloads/user-guides/?keyword=VG910&x=17&y=5
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2010 | ViewSonic VG910 (Black) 19" LCD Monitor
Insignia 22'' LED HDTV screen resolution problem with VGA
This is more of an alternative than a solution... but I solved my problem by getting a dvi to hdmi adapter and connecting to my mac desktop via hdmi. Once I then turned off the overscan in the menu I got a perfect 1080p image. Hope this helps. :-)
Dec 20, 2009 | Insignia Televison & Video
PC to television hook-up
It's possible yes.
You'll need a RGB cable and a 3.5mm stereo minijack cable. Set resolution to 1024x768 or 1360x768. Plug from PC to INPUT 6 on the back of the TV. Press menu on the remote, go to SETUP and go to INPUT SIGNAL. Change the resolution to 1024x768 / 1360x768. Or, go to the AUTO SYNC. and select YES.
After all that, Press PC button on the remote and it should work like a computer monitor.
May 30, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Pc mode
To get the best picutre set your PC to a resolution of 1360x768. Then press the adjust button on the remote to set the TV to the same resolution.
Jan 02, 2008 | LG 42LC2D 42 in. LCD HDTV
Microsoft Windows XP Media Center Edition 2004 for PC Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
