NA-F5001T details
Top load washing machine
Junoon007
  • 1011 Answers
SOURCE: My whirlpool top loader extra large washing macine
Dear Sir/Madam,
What is the Model Number of your washing machine?
Posted on Aug 07, 2008
  • 326 Answers
SOURCE: My Kenmore washing machine, top load, will not
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 06, 2009
SOURCE: Top loading kenmore washing machine frozen water loaded
Could it be that it has overheated? My mom's washing machine isn't a kenmore, but it has a mechanism that causes it to stall when it is overheated from constant use. After about 15 minutes it cools off and starts again.
Posted on Aug 07, 2009
  • 41 Answers
SOURCE: water will not drain out...checked drain pipe and
Pump impellor pin broken
Posted on Sep 03, 2009
  • 1531 Answers
SOURCE: Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Posted on Jan 23, 2010
Sharp es 950 top load washing machine as on same time beeping and showing e2
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to washing machines are given.
Dec 07, 2015 | Washing Machines
Zanussi washing machine wont stay on the setting for a quick wash.
perhaps the half load switch is faulty... or just grubby
na...
or more over the machine has detected you placed more than 4KG in the half load??? did you do this ?? fine
this is the issue
http://www.manualslib.com/manual/199558/Zanussi-Zwn-6120-L.html?page=10#manual
Mar 05, 2015 | Zanussi ZWN6120L Washing Machine - White
My Panasonic top loading washing Mch model NA-F70G5 has no lite or power tks
In most cases ,problem is main control board on most front load washer
Oct 03, 2014 | Panasonic Washing Machines
Error code h20
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Mar 26, 2014 | Ariston Technologies AW 129 NA Washer With...
How to open front panel
There were two (2) small screws at the very bottom of the front.
  • Remove them securing the dryer front access panel to the dryer cabinet.
  • Lift the panel until the tabs can be disengaged from the cabinet.
  • Remove the panel and set aside.
Installation Manual (see page 8)
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131661700p1-8.pdf
Owner's Guide
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131781700ceen.pdf
Operating Instructions
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131919500e.pdf
Cutout Dimensions
http://www.frigidaire.com/products/images/documents/cutout_dimensions/lc.pdf
Energy Guide
http://www.frigidaire.com/products/images/documents/energy_guides/134089300-USA.pdf
Feb 18, 2014 | Frigidaire GLET1031 Top Load Stacked...
Panasonic Top Load Washing Machine (NA-F70A6) won't drain
Try to yank the clogging by a small gripper claw tool that you can purchase from ACE hardware. It is like a long tool with a push end that when you push, a set of 3 small claws go out. This would go in between the tub and the drum.
Jan 14, 2014 | Washing Machines
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine not working
Before switching the "on" switch select your programme, ie whether you want spin, wash, etc. Then put the "on" switch on.
Mar 02, 2007 | Ariston Technologies AW 129 NA Washer With...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
