Don't light, y no LCD connected, them blinking
Edwin kicked and broke the monitor. Then he charged $760. Touch screen has a big crack.
Posted on Nov 05, 2012
  • pacomismo_ro
    pacomismo_ro Nov 06, 2012
    No, touch works fine
    Genius:
  • 2,432 Answers
Can you please give detailed problem of your monitor so i can give you much better solution.
Posted on Nov 04, 2012
  • pacomismo_ro
    A monitor with touch LG Phillips 150X08 installed on a POS. when the monitor fluorescent lights work well for two or three seconds until turned off. Turn on when switched to graphics mode windows, for two or three seconds. If I disconnect the screen and leave only the fluorescent connected to the "Inverter" start flashing. I tried with the same result other fluorescent. I think that this is the "Inverter", specifically the two capacitors that are in parallel with the output, but wonder both present the same problem, although I can not say that one stop working some time ago.
  • pacomismo_ro
    Graphics card works fine with other monitor.
Coby HD LCD TV Blinking and Flickers ?
It sounds that the problem is with its back-light inverter baord itself
May 28, 2013 | Coby TFTV3225 32 in. LCD TV
Problem With the Sharp TV LC-32SB23U 32in LCD TV Serial No# 810825838
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 25, 2017 | Sharp LC-32SB23U 32 in. LCD TV
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
I have a problem .. I have a mrv t757 amp and it isnt bumping like I used too .. If i keep the volume low all 3 lights are green but once I turn it up it blinks red n yellow n green back andn for in the...
check all your connections to make sure you don't have a short, but most likely it's your amp. If it was the battery it would turn on and off, including radio, then your car wouldn't start(dead battery), but if it does this and your car turns on no problem then it sounds like the amp gave out.
Aug 23, 2011 | Car Audio & Video
I own a linksys E1000 wireless router. After a storm & power blink-out, I could not access internet. Notice the 1,2,3,& 4 lights not lit. all other lights on right side were blinking. When I...
Normally on the back of the routers there is a small reset button you can press and hold for 15 seconds. This will reset the unit.
Click here for linksys tech support page. At the bottom there is a live chat option.
-G33k
Aug 09, 2011 | Cisco Linksys Wirelessn Router Black...
The blue remote wire where do i connect it and how? Is the head unit the deck car deck i mean? No power light
The blue remote wire is a wire that you connect to an amp which will turn the amp on when the radio turns on. If you don't have an amp don't connect it, just tape it up
Jul 12, 2011 | Car Audio & Video
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
