Question about Quasar SP-2719 27" TV
My tv has power but no volume or picture
I have a big screen tv from early 200's it is not a flat screen or plasma. The tv has power but I can not see a picture and I cannot hear anything.
  • Anonymous Apr 07, 2009
    i have the same problem it just happened randomly i've only had it just over a year and when i turned it on there is power but no picture
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Toshiba 42HP86 Plasma TV. No picture, but sound is there
the same thing happened to our 42 HP86 red smow at the top than one day now pcture just sound... we took ours to a television repair shop and said we needed a power source wich would cost about $200 and another $200 for the labour so we were looking at a total of $486 plus taxes..... we still dont know what to do when we bought the tv it was $2000 back in 2004.
Jan 16, 2010 | Televison & Video
Picture problem
You need to replace the Ymain and the buffers. This is a very common problem with this set, and its magnavox and samsung counterparts. Look throught the other solved postings for a detailed description of how to dismantle and replace. Plan on spending at least $200 on this repair. Likely a bit more.
Jul 26, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Lg tv has vice ut no pictures
No I did hear a pop or anything it just make sound but no picture
Dec 15, 2008 | LG 42LC2D 42 in. LCD HDTV
No pic or sound
If you have confirmed that your power cable is connected properly from your TV to the wall outlet (bypass surge protector strip if you are using one), then no picture and no sound is typical of SMPS (Power Supply) board gone bad. It can cost upwards of $200 plus labor. The good thing is, LG generally offers two (2) years parts and labor warranty for their big screen TVs. LG Repair turn around time is usually fast. Goodluck!
FixYa!
Jun 30, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Sony Flat Panel tv with no Picture
Flat panel TV's typically do not have "bulbs," but rather backlighting.  Plasma displays are especially touchy during movement.  I would suggest checking your warranty status, as it's probably not something you can easily repair.  If you wanted to take on the repair yourself, be careful not to lay down the screen, as it will drastically shorten the life of the Plasma display.  I would start with checking the system boards for possible damage, since you did hear a "click," It was probably a fuse, chip, etc.
Oct 19, 2007 | Sony PFM-42X1N 42 in. HD-Ready Plasma...
Televison & Video Logo
129 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
