Dvd will not eject
Hi turning machine on and keeps saying close and i cant eject it
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Someone is going to have to open the unit and LOOK to see if disc jammed or out of position---it is possible in that case to gently with a Q-tip etc to move it a bit back and then unit may work.
Look only to see what is happening when you try to eject first.
Posted on Nov 03, 2012
epik559
  • 44 Answers
SOURCE: Remote Buttons
Press the VCR button first then press open/close
Posted on Nov 25, 2007
  • 168 Answers
SOURCE: Stuck dvd in the machine on top of one in there already - cannot eject - help
If you are comfortable taking the cover off, you can try removing the cover and remove the dvd's yourself.
IF you are not comfortable removing the cover then, you can try to take a credit card (Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
And in the Future, with any other CD/DVD Players, use your remote control or the open and close button to open and close the tray, and NEVER Push on the tray itself. If I had a dollar for every dvd player tray that Ive fixed because of this, I would be buying bill gates dinner. (not really, but you get my point)
Good luck.
Mac =)
Please post a rating or feedback if I have answered your question.
Posted on Mar 21, 2008
SOURCE: lg dvd drawer opens by itself and wont stay closed
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
Posted on Jan 28, 2009
SOURCE: cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Posted on Feb 19, 2009
SOURCE: It keeps ejecting the disc and saying disc error
Now what this joker isn't telling you is that the 'hack' below actually resets the player to factory defaults. It just worked for me perfectly.
Now you might have to go back into setup and readjust some of your settings. (i.e. freq response)
1. press SETUP on the remote
2. Go to "TV Aspect" and move the cursor to "16:9"
3. Press in order: 1, 3, 9, 7, 1, 3, 9 on the remote, then press ENTER
Posted on Apr 13, 2009
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
I cant eject the DVD. It keeps saying "Please
Try pressing repeatedly the eject button while you turn on the unit. If this doesn't work then it is a mechanically problem in your player.You need to be manually open to take out the dvd.The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.
You need to place the rubber thread to proper place.
Furthermore, if the belt is slipping, the mechanism never gets the "drawer closed" signal, and the disk will not spin.
After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. So it indicates the defective laser motor. The only way to fix this problem is to bring the unit to a service center for repair.
Hope this helps.
Please feel free to ask us if you have any further queries.
Shane
Feb 13, 2011 | Kiss Technology DP-600 DVD Player
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
DVD DRAWER won't open
OK.
I assume the display does not say 'locked' when you press eject.
A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common)
The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this.
A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case.
Testing:
Bad belt - the DVD drawer shifts a bit when the eject button is pressed.
Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display.
Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
Mar 22, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Cannot eject DVD or turn off machine or anything
Feb 19, 2009 | JVC DR-MV5S DVD Recorder/VCR
Remote Buttons
Nov 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
RCA RTD210
you should never use a disc thats scratched inside yiour machine its most likely your dvd machine is having trouble reading your media the best way to solve this is to unplug your machine wait turn it back on keep pressing eject it should eject dont use that dvd disc again hope this solves your problem did for me ;
Jul 31, 2007 | RCA RTD210 System
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
