Question about Astar LTV-3201 32 in. LCD Television
HOOKED UP MY NEW TV WITH COMPONENT CABES TO THE DVD. THE COLOR IS PINK. CABLES ARE NEW. I KNOW I HAVE THE COLOR CABLES MATCHED CORRECTLY. COULD IT BE THE CABLE OR DVD.
The problem is that the tv is set to 480I or 480P. Try changing the setting to 720P or 1080I and the pink color should dissapear.
Posted on Jan 10, 2009
How can i hook my dvd player to the tv
Color codes on cables must match up to matching colors on dvd player
Nov 05, 2014 | Monster Cable J2DVD-CHP10 Just Hook It Up...
Dvd color mostly blue and pink, colors look weird
try connecting thru an hdmi cable from your dvd player to your tv, check the colors then.. I'd say you have crossed your component cables.. match the connector letters a/b/x? and plug them in one after each other.
Nov 05, 2007 | Konka KDL-37AT23U Television
No color
sounds like the cable hook up may be wrong.check that all cables are correctly matched by color to the plugs on both the tv and the dvd player.Make sure all components are turned off before doing this. Also try unplugging all cables that connect dvd to tv and then reconnect.Check cables for any frays or cuts,replace if necessary. Also try this link if none of the above help: http://esupport.sony.com/US/p/model-home.pl?mdl=DVPSR500H&LOC=3&session_id=8c3d6382bd67858dd90a5bb0cab1f8e3#/howtoTab
Apr 19, 2014 | Sony DVP-SR500H DVD Player
Blue colors are now green.
It sounds connections are not matched yet. Make sure connections are green to green, red to red and blue to blue in dvd player and tv are correct.
Try another component video cable.
If problem still exist, test dvd player to any other tv, found ok then component input of this TV is bad, need to get it repaired.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
I amm trying to set up an vsx817 pioneer receiver to play dvd
on the rear of the receiver,hook your red,yellow andwhite cable to the input labled DVD and match the corosponding colors to the DVD player output. if your using component hook up match red, green and blue on both units and also a component cable to your tv
Nov 11, 2008 | Pioneer Televison & Video
Dvd picture
Make sure component cables match colors between Television and DVD player. It should be TV input to DVD output. Try to play at least two DVDs to make sure its not a single DVD that may be having an issue. Also, adjust your television's picture setting to make sure its set to normal. Also access your DVD players menu to make sure the setting are set to normal as well.If it doesn't correct the problem, use a different component input on your television. If problem persists, you may need to contact the DVD player manufacturer to see if its still under warranty and not defective. Good Luck.
Oct 18, 2008 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Dvd screen is pink
If you are using component cables to connect the DVD to the tv make sure you have the red,blue and green colors on your cables matching these colored jacks on the tv and DVD jacks. If one of these cables is plugged in wrong or not plugged in it could cause this. Good Luck
Jan 04, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Astar LTV-3201 32 in. LCD Television Logo
97 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
