From what I can tell and after researching the same issue it is the KRZR. I called both Verizon tech support and my bluetooth tech support. There is no solution If you notice some of the functions in the Blue tooth Pairing/connection menu functions don't even work. (The on off for instance and the settings) After it is paired. I tried my bluetooth with other phones and it works fine. I am going to the Verizon store to complain untill i get a different model.
how can i change my phones language from spanish to english? All displays are in spanis now. My...
(More)
how can i change my phones language from spanish to english? All displays are in spanis now. My phone is motorazer v3
I have a Motorola RAZR v3m, and whenever it is on from anywhere between 2 and 5 minutes, the screen...
(More)
I have a Motorola RAZR v3m, and whenever it is on from anywhere between 2 and 5 minutes, the screen will turn white, and then it will return to normal, but the only difference is that the keypad doesn't work at all. The only way to get the phone to work again is to remove and reinsert the battery. I have done that about 10 times now, but each time I do, the same thing happens again.
