I have looked in control panel
SOURCE: device manager is gone from control panel
In Windows XP it has moved. Double-click System, go to the Hardware tab and you will see it.
SOURCE: control panel does not show bluetooth icon. Why?
Run services.msc (which is the service management tool)
You should see a Bluetooth Support Service, set this to start and then have it automatically start with windows as well.
Bluetooth control panel application: bthprops.cpl
Bluetooth listed in my actual control panel.
However you may need to reinstall BT again and check for the properties of it.
Please check the steps and let me know if it works.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
